Technical Front end leaning
Discussion in 'Traditional Hot Rods' started by Towtruckjoe, Jun 7, 2025.
  1. Towtruckjoe
    Towtruckjoe
    Looking for some advice. I have a 29 Model A Tudor. The front end leans to the drivers side. New aftermarket frame. Traditional cross leaf in front with tubular drop axle. Vega cross steer. Adjustable coilovers in the rear. I have the rear coilovers adjusted so the back end is level. The front still has a noticeable lean of about 1” at fender height. Weight is distributed throughout car. Battery on one side and toolbox on other side that weighs about the same on other side. I’m thinking of maybe trying an angled spring shim like you can get to change pinion angle on a rear differential. Any thoughts or suggestions?
    dana barlow likes this.
  2. manyolcars
    manyolcars
    first, swap ends on your transverse spring and re-install it.
  3. KevKo
    KevKo
    from Motown
    Agree with anbove, and leave bolts loose until it is at ride height, then tighten everything.
    dana barlow and Just Gary like this.
  4. woodiewagon46
    woodiewagon46
    from New York
    Make sure the "U" bolts that anchor the spring in the front crossmember are tightened equally and not pulling down the drivers side.
    dana barlow and Pist-n-Broke like this.
  5. alchemy
    alchemy
    Make sure the center bolt in the spring is in the crossmember hole. Also make sure your fenders are actually level.
  6. Dan Hay
    Dan Hay
    Pics would help, might be an optical illusion with the fender fitment
    Pete Eastwood likes this.
  7. Mr48chev
    A batch of solid advice in the previous posts. I'd follow though with their suggestions.
    One thing that I know for sure is that if one is a bit on the well fed side and drives alone most of the time their vehicle like that one over <<<<< in my avatar will lean to the left because the drivers weight was on the left side and there was no matching weight on the p***enger side most of the time to balance it out.
    From an old front end mechanic who leveled a lot of cars at a new car dealership over the years, Step ne is to check tire pressure in all 4 tires with a good gauge and make sure it is spot on even. Then do the measuring and off the frame rails might be as important as off the sheet metal.
    GasserTodd likes this.
  8. Pete Eastwood
    Pete Eastwood
    from california
    For the back to be level and the front to lean, the frame would have to have a twist in it.
    You say it's off by an inch at the front fenders.
    Are the fenders properly aligned? Does the radiator lean to one side?
    Find a good flat surface to park the car on.
    Measure from the ground up to the frame on all 4 corners.
    Don't blame the ch***is until your sure the fender fit is the same from side to side.
  9. Rock Buster
    Rock Buster
    I have the same dilemma on my ‘33 Ford, with the leaf spring front end, coil over rear end. It is 1 inch lower on the driver’s side. I’m thinking about adding adjustable coil over shocks to the front, but unsure of what spring rate to get, being that I already have a leaf spring. Any advice would be greatly appreciated.
  10. pprather
    pprather
    When I took the buggy spring/axle off the front of my rod, there was a small spacer or wedge on one side of the center bolt, between the spring and crossmember.
  11. Towtruckjoe
    Towtruckjoe
    New TCI frame. Coilovers in rear are adjusted so the back end is level. It’s not a weight distribution problem. Leans to drivers side without my slightly chunky 180 lbs in it. Fenders appear level. Maybe I will measure frame horn height and both frnder heights to get idea if fenders are off
  12. Rock Buster
    Rock Buster
    I worked on mine today. It’s not consistent. The problem seems to be because the shackles don’t always sit at the same angle. When the shackles are sitting at the same pitch/ angle, the front end is level. ??
  13. Rock Buster
    Rock Buster
    I adjusted my Panhard bar today, thinking that pulling the p***enger side in would raise the driver’s side. That didn’t happen. I’m going to switch the leaf spring end for end tomorrow. If that doesn’t help, I guess I’ll have to get adjustable coil over shocks.
  14. alchemy
    alchemy
    Have you all done what Pete said? Park it on a flat spot and measure the frame to make sure it’s flat? It’s very likely that the fenders are messed up. Especially if you both say the rear of the cars are level.
