Hot Rods Front end question
Discussion in 'The Hokey Ass Message Board' started by harleycontracter, Jun 27, 2023.
  1. harleycontracter
    harleycontracter
    Can I use a 33/34 original axle with 40 spindles and 46/48 Ford juice brakes in my A? Txs
  2. Dave G in Gansevoort
    from Upstate NY
    I know the spindles will fit using the 37-40 kingpins. Never used any old Ford brakes so someone else will have to answer that.
  3. walls
    walls
    Yes.
    If using the stock wishbone, you’ll need a spacer for the axle.
  4. Marty Strode
    Marty Strode
    You will have to heat and bend the steering arms down to clear the wishbone.
  5. 31Apickup
    31Apickup
    The brakes will bolt up no issue.
