front end question
Discussion in 'The Hokey Ass Message Board' started by pdub, Feb 20, 2007.
  1. pdub
    pdub
    Might be a dumb question but is it poss. to install spindles upside down? Being a bit new to the scene I bought a Speedway Motors complete front end. It was real reasonable. When I installed the spindles and king pins, they looked identicle to each other. Now that everything is together the left wheel seems basically 90 deg. and the right seems at about 80deg. Is there somthing stupid I missed? Any help would be greatly appreciated. Thanks,
    Paul
  2. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    Sure looks whapperjawed to me. Looks like you might have put the right hand spindle on upside down.
  3. Rootie Kazoootie
    Rootie Kazoootie
    from Colorado
    Yep, the top king pin boss is the one furthest away from the spindle flange.
  4. pasadenahotrod
    pasadenahotrod
    from Texas
    You're not the first to do this, and won't be the last!!
  5. 38Chevy454
    38Chevy454
    It can be mounted upside-down, but your kingpin inclination is going to cause the spindle angle to be way off, as you have demonstrated. I agree that your p*** side is probably mounted upside down.
  6. pdub
    pdub
    Survey says...........I'm retarded. So it's just that simple, huh? Thankyou......a 6 pack is on the way to you all.
    Paul
  7. butch27
    butch27
    Looks like a good circle track set up to me.
  8. On a totally unrelated note, pdub, your picture convinced me to use the speedway complete frontend kit. I've been wondering what that kit looked like. Thanks!:)
  9. el chuco
    el chuco
    It doesn't matter how much negative camber you have on that wheel-- as long as your lovely young p***enger is smiling like that,you're doing a fine job.:D
  10. Royalshifter
    Royalshifter
    Moderator
    Are they chevy spindles?
