Hot Rods Front end too low on a 1939 ford
Discussion in 'The Hokey Ass Message Board' started by wilnov, Jan 6, 2019.
  1. A 39/40 Ford is only too low if you can't get into the driveway. LOL
    lothiandon1940 and olscrounger like this.
  2. olscrounger
    olscrounger
    ^^^^ This-need pics. Have done a lot of 40's-doing a std coupe now and a 39 woody. Both 4" axle, reversed main leaf,9 leaves, centered 15x6" wheels and 195/65 front tires--sit just right and not too low.
    lothiandon1940 and porknbeaner like this.
  3. treb11
    treb11
    What's the tire diameter? lots easier to change tires than springs.
    porknbeaner likes this.
  4. Stan Back
    Stan Back
    I had one re-arched at a local spring shop years ago. The guy traced the arch on the floor with chalk, turned the spring over and rolled it a couple of times thru some adjustable 3-roller set-up until the spring had the same arch as before – it just was on the other side. Took about 5 minutes, charged me $10 or so.
    A lot cheaper than buying another spring, having to buy new u-bolts for added leaves, or buying new tires.
    lothiandon1940 likes this.
  5. Bandit Billy
    Bandit Billy
    Good to see you posting again ******! You are correct as per frickin usual :cool:...unless the OP has a wheel backspace issue. May be why there is no pics.:rolleyes:
    olscrounger and lothiandon1940 like this.
  6. treb11
    treb11
  7. DOCTOR SATAN
    DOCTOR SATAN
    from okc
    Spacer, get it right where you want then...
