has anybody put a chevy front end under a 63 ford truck f100 2x4 just wondering because i dont like the looks of the steight axle and leaf spings and i have a 83 chevy front end with disk brakes i think it would be easier to lower to?
Guys have probably thought about it but I would get the tape measure out and see how close the frames are in width right at the "axle" center line. I think that the Ford frame is several inches wider than that Model of Chev frame. There have been posts on here that have discussed putting a later Crown Vic crossmember and suspension under pickups and they fit that model of F 100 pretty well but the wheel selection is pretty limited as those Sedans have a pretty wide track. Here, see what Carcrafter22 did on his truck http://www.ford-trucks.com/forums/716058-buildup-06-crown-vic-front-suspension-into-67-f100.html
thanks i have been pondering on it for a while now the chevy frame is wider and will slide together ,i already have a chevy 350 in it so all that stuff should go back in with out a problem
