History Front Engine Dragsters-Wheelbase Through The Years
Discussion in 'The Hokey Ass Message Board' started by Richard D, Jan 4, 2012.
  1. We all know they got longer as time went by. Anyone care to break it down and give us a history lesson? Maybe some info or photos of frame/rollbar design through the phases?
  2. kisam
    kisam
    Garlit's web site is a pretty good indication. Here is what I pulled from it maybe someone can fill in the blanks.
    Yr /Swamp Rat #/Wheelbase
    '56 1 ?
    '59 1B ?
    '62 111A, B,C ? First year he used Chrome Moly Tubing
    '62 5A 120"
    '63 5B 140"
    '63 7A 140"
    '63 8 140"
    '66 10 175"
    '67 12 215"
  3. BillWallace
    BillWallace
    For some reason it was thought that dragsters shouldnt have long wheelbases in the mid 50s & Scotty Fenn even had a theory that the wheelbase should match the cir***france of the rear tire. Finally everyone figered out you needed to keep the front tires on the ground to steer the car & use weight & leverage to do that.
  4. H.G. Wells
    H.G. Wells
  5. ChassisResearchKid
    ChassisResearchKid
    from Michigan
    Roughly it work s out from 1960 it would have been 10 inches per year starting with a 100 inch car. So in 61 it would have been a 110" wb. 62, 120. 63, 130 and mid year 64 145" hence the wheel base of my new car. These are rough figures, but gets you in the drag strip (ball park).
  6. Russco
    Russco
    from Central IL
    That seems about right my dad had a 150" car in about 65 or 66.
  7. c-10 simplex
    c-10 simplex
    So what IS the advantage of longer wb? Stability? Wouldn't shorter wb=faster weight transfer to rear wheels?
  8. dreracecar
    dreracecar
    from so-cal
    Leverage
    As tires and engines, clutches evolved you could move the weight foward by lenthening the ch***ie thus fooling the reaction (the tendency of wheelstanding)without adding any weight.
