1952-59 Ford Front Fender Bolts
Discussion in 'Off Topic Hot Rods & Customs' started by 55newbie, May 27, 2019.
  1. 55newbie
    55newbie
    from Ohio
    Trying to remove the front fenders on my 55 Fairlane. I have the core support, and inner fenders out, removed the top and bottom fender bolts. There are still bolts hiding somewhere near the fire wall. Any suggestions where they are?
  2. jimmy six
    jimmy six
    does the grille need to come out. My 56 did, along with the silver plate under it.
  3. 55newbie
    55newbie
    from Ohio
    I took everything off the front end. The fenders are just hanging near the firewall
  4. green53ford
    green53ford
    from Wisconsin
    I don't know about 55 56 but on 52 54 there is a bolt that you have to get at from an access hole in the door jam.
    Black Wagoon and danman55 like this.
  5. danman55
    danman55
    Remove the kick panels on the interior to access the nuts. There is a stud on each fender that goes through the side of the body in those locations and each one is held on by a small nut. I think it is still 5/16-18? thread size and uses a hex head nut 1/2” in socket size. There are two bolts with 1/2” heads underneath the fenders as well. Usually these are rusted up since they sit upside down. Maybe that is what you mean by bottom fender bolts tho?
  6. 55newbie
    55newbie
    from Ohio
    Thank you, I greatly appreciate it
  7. HOTRODPRIMER
    HOTRODPRIMER
    It took me a while to figure that out when I was removing my fenders. HRP
