Technical Front I Beam Axle 40 Ford Coupe
Discussion in 'Traditional Customs' started by jumbogem29, Jun 30, 2024.
  1. jumbogem29
    jumbogem29
    from Alabama
    Any one running a Pete Jakes 1105A axle in their 40 ford would like to see pictures of how the car sets and wheel and tire size i think its 46 king pin to king pin 4 inch drop uses your stock bones . Looking 4-5 drop on a coupe thanks
    anthony myrick likes this.
  2. alchemy
    alchemy
    You would also need to know the specifics of the spring. On a 40 you can do a lot of lowering with the spring.
  3. jumbogem29
    jumbogem29
    from Alabama
    Yes thanks spring is important looking at 4 inch drop or 5 and when you go with a deep drop like that will it change your caster as well do you have to moify your wishbones as well
  4. Wouldn’t the drop help get a little more caster which is good?
  5. okiedokie
    okiedokie
    from Ok
    You will have to spilt your wishbones, or use 36 wishbones I believe.
  6. krylon32
    krylon32
    from Nebraska
    My 40 coupe has that axle and a Posie reversed eye low spring, Unknown tube shock kit and an anti roll bar. And for some strange reason split 46-48 bones? Rides good and has plenty of turning room. It sits a little higher than a lot of guys like but out here in flyover country it's just fine. It was originally built by a 40 Ford guy in the Sacramento are. I rescued it an brought it to Nebraska where we went completely thru it doing lots of updates with OleScrounger as my tutor.
    lothiandon1940 likes this.
  7. jumbogem29
    jumbogem29
    from Alabama
    Thanks for the replys .
