front seal on oil pan
Discussion in 'The Hokey Ass Message Board' started by guido`s 40, Feb 3, 2013.
  1. guido`s 40
    guido`s 40
    from nebraska
    I have a aluminum timing cover and oil pan and even with the narrow seal it seems to be too thick. I know that around pre 74 takes the narrow front seal and I have both with the gasket set but when I set the pan on it has about a 3/8 gap between it and the rail
  2. lothiandon1940
    lothiandon1940
    You might want to mention that you're talking about a SBC just for the record, and yes there is a thin and a thick front seal. It sounds like it may be a discrepancy with the aftermarket pieces, the pan and the timing cover. Are they from the same manufacturer?
  3. guido`s 40
    guido`s 40
    from nebraska
    sorry I forgot to add that but it is a sbc and yes both pieces came from the same place. I will call the tech line this week, I was just trying to make sure I wasn't missing something
