Front shackle question
Discussion in 'The Hokey Ass Message Board' started by sephgato, Aug 5, 2009.
  1. sephgato
    sephgato
    from fenton
    I am setting up the front end on my A and have a question, I have a 26" spring but I have a 46 ford axle so the perch pins are much farther apart than that. I am running the axle suicide, is it okay to make a set of shackels that are long enough to use this spring? Theoretically it should work but I wanted to double check.
    Thanks
  2. 1rustyhighcab
    1rustyhighcab
    you'll need a longer spring. I would think that longer shackles will bottom out on top of the axle.
  3. hvychvy
    hvychvy
    I would for shure run the correct spring.Never can be to safe with your frontend:)
  4. Hot Rod T
    Hot Rod T
    Posies makes the right spring but they don't list it in the catalog .I bought one last year. I can look up the part # if you want
  5. sephgato
    sephgato
    from fenton
    The spring is behind the axle though, I am wondering if it would cause the spring to behave as though it were too soft or if it would create a major amount of roll when turning. I am going to change the spring, I am just curious what the potential issues of having a longer shackle in the front is, if any
  6. onlychevrolets
    onlychevrolets
    or shorten the axel, I took an inch and a half out of my 40 axel to do a spring over. The axel is cast steel so welding it is not a problem, as long as you know how to weld. I've been beating on mine for three years with no problem.
  7. BangerMatt
    BangerMatt
  8. pasadenahotrod
    pasadenahotrod
    from Texas
    The Ford suspension is designed for the spring to be in tension when mounted. That's why a spring-spreader is necessary for any pre-42 Ford spring to be installed and a Panhard bar is not necessary.
    With longer shackles and an untensioned spring a Panhard bar is necessary to eliminate shackle sway which is what Ford did on the 42-48 passenger cars.
  9. Ned Ludd
    Ned Ludd
    Geometrically it should be possible - if there aren't clearance issues. The important thing is that the shackles sit at the same sort of angle - say 5° either way - as the stock shackles.
    Is your dimension of 26" installed or not? with the weight of the car on it or not? Remember a leaf spring will increase in length at it is loaded.
    Long shackles will tend to reduce the roll centre migration effect. If the new shackles are a lot longer you might find that relatively mild lateral acceleration now corresponds to silly roll angles, so an additional axle lateral-locating device might be needed. If you've got one of those the shackle angle becomes less important, but closer to vertical is then better.
  10. sephgato
    sephgato
    from fenton
    I set it up just to see what it looked like, when loaded they should be about 50 degress or so.
    I will most likely change the spring but was interested in how it would work.
    The ground clearance is what I think could prove to be a problem.
  11. hrm2k
    hrm2k
  12. hrm2k
    hrm2k
    TTT for the day shift...anyone have the answer to the correct angle?
  13. Little Wing
    Little Wing
    from Northeast
    sorry but shortening the axle just seems silly,,why ruin the integrity of a perfectly good axle ,,when finding a proper spring is no big chore ?? :confused::confused:
  14. bobscogin
    bobscogin
    About 45º with the axle loaded.
    Bob
  15. no kidding.. and why put a 26" spring on a 46 axle? I am just curious.. the 46-48 Ford I beams were the widdest ones Ford put under their cars (Lincolns were a bit wider) so what is the reasoning for putting such a narrow spring? Lowering maybe? or a severe pre-loaded front suspension.. inquiring minds want to know :D
