Technical Front shocks recommendation?
Discussion in 'The Hokey Ass Message Board' started by Never2old, Sep 16, 2018.
  1. Never2old
    Never2old
    from so cal
    Ok I bought shocks that MIGHT work on an independent front but are way too stiff
    compression for my buggy spring setup.
    I need them to be chrome and 11" long at ride height with 5/8" dia. eyes at both ends.
    I can re-bush them if I have to.
    Can I get a (some) suggestion(s)?
  2. lostone
    lostone
    from kansas
    Empi makes some hydraulic non gas charged shocks for old Volkswagens. 9650 part number I believe.
    I ordered 4 for the front and rear of my model A. I really like the feel of them in my hand. BUT the eyes will either need replaced or the steel bushings drilled.
    In fact this week I will be trying to drill the front lowers out to 5/8" .
  3. Atwater Mike
    Atwater Mike
    The 'short shocks' you seek were Gabriel, for '49 Plymouth p***enger car...
  4. RMR&C
    RMR&C
    from NW Montana
    Problem is, every modern shock is now gas charged.....and they **** on any fairly light solid axle hot rod. IMO
    AHotRod likes this.
  5. butch27
    butch27
    Especially a t bucket...Yuck
    AHotRod likes this.
  6. Happydaze
    Happydaze
    Bilstein. Chrome. Choice of3 lengths. Available Speedway and others. Don't recall anyone saying anything detrimental about them. I have them f&r on a project, expect them to be great.
    Chris
    gimpyshotrods and da34guy like this.
  7. Torana68
    Torana68
    from Australia
    The gas only stops the oil from foaming and becoming useless, if the valving for your purpose is wrong ( to stiff or not stiff enough on rebound or compression) gas or no gas won’t make a difference. Why not buy So Cal shocks ? Bilstein are great though.
    Ned Ludd and gimpyshotrods like this.
  8. da34guy
    da34guy
    X 2 on Bilstein.
    gimpyshotrods likes this.
  9. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Cheaper option is the street shocks from speedway motors. they make one 12" ride height that should be good for you, chrome. QA1 makes a Street Star I think that's chrome and is about same dimensions. Both these options are only Oil filled with NO gas. Speedway are the cheapest version, they held up good on my Tudor for many years, I have QA1 on the back of my 56 and they do great also. Billstein are good just too dang pricy and are gas charged mostly.
  10. lostone
    lostone
    from kansas
    FYI I drilled the bottom on the empi shock ferral out to 5/8" with no problems today. Just lots of oil and go slow.
    Btw you can find them on line for around 20. Each and again NOT gas charged ;)
  11. Malcolm
    Malcolm
    from Nebraska
    X3 on the Bilstein shocks. I've been very happy with the set of four on my roadster.
  12. TurboRider
    TurboRider
    Just wondering if you got the Bilstein or you opted for another brand of shocks?
  13. Never2old
    Never2old
    from so cal
    Turborider, I determined that my problem is my front spring.
    My engine/transmission I ***ume, are lighter than what the spring was designed for.
    I used a shorter than stock spring along with a narrower axle so that my tires fit beneath the fenders.
    I will need to remove leafs and probably re-arch some to get the ride height and spring rate I want.
    I don't expect it to be a simple task but what's new?
    I can determine if the Beilsteins are to my liking when I have accomplished the above.
    I am heartened by the replies by Happydaze, Malcolm and da34guy.
    Thanks for all the feedback.
    I will report the final results.
    harpo1313 and lothiandon1940 like this.
  14. custom_lettering
    custom_lettering
    from Wall, NJ
    Only Bilsteins here.
  15. Stock Racer
    Stock Racer
    Just went through this on my OT Race Car. I felt that the shocks were way too stiff. Sent them to a guy with a shock dyno that has been setting up shocks for 30 years. He told me that a car (even a light car) will do things to that shock that you will never do by hand on the bench. He was right. They are now set stiffer than where I thought they were too stiff and they work great.
    Ned Ludd likes this.
  16. LBH
    LBH
    QA 1 double adjustable ....
