Technical front spreader bar license plate mount?
Discussion in 'Traditional Hot Rods' started by bad_azz_bmr, Feb 7, 2014.
  1. bad_azz_bmr
    bad_azz_bmr
    from BC
    I would like to mount a license plate onto the front spreader bar of my A sedan, I have seen a few mounts online and they are more than $60 for a pair and speedways cheaper $30 mount is only available in 1-3/4" or 2" diameter (mine is a 1-1/2" bar), has anyone used a set of motorcycle fork turn signal clamps for this application?
    http://www.ebay.com/itm/Motorcycle-...Parts_Accessories&hash=item3f2efd711e&vxp=mtr
    The above mount is for a 39mm (1-1/2") diameter tube which is the same as the spreader bar diameter.
    This mount would only allow for 2 screws into the plate instead of 4 like the other mounts.
    Any advice would be much appreciated.
    BTW I am from Vancouver BC, Canada where a front plate is mandatory.
  2. 325w
    325w
    Have looked at the front plate for a 32? One hole drilled thru the bar and a screw down the middle.
  3. i don't think that eBay one would give enough support with the wind at highway speeds
    go with stock as suggested or make one yourself out of aluminum....maybe 1/2" thick? band saw it out , bore a hole , split it ,then drill and tap. it would be a nice simple project
  4. cadillacoffin
    cadillacoffin
  5. bad_azz_bmr
    bad_azz_bmr
    from BC
    Yes I saw the original style, where it bolts through the bar, but I would prefer something that is removable.
  6. bad_azz_bmr
    bad_azz_bmr
    from BC
  7. Canuck
    Canuck
    This will be bolting onto the rear of the spreader bar on my 30 coupe. just waiting to get things more together to set the angle.
    May not be hot rod traditional, but the clamp/support parts are pre 48.
    Just another idea for thought.
    Canuck
