Front Spring Perches
Discussion in 'The Hokey Ass Message Board' started by Little Wing, Mar 6, 2009.
  1. Little Wing
    Little Wing
    from Northeast
  2. bikersteve
    bikersteve
    If there's a welding shop near you they should be able to make one
  3. Make a cardboard patern of what you need and take it to the nearest trade school or high school metal shop cl***. Oh, and when they ask, it's a support bracket for some kind of farm equipment.
  4. Little Wing
    Little Wing
    from Northeast
    k,,I'm guessing 3" is some kind of standard size..
  5. tdoty
    tdoty
    Yep, 3" is pretty much the standard. I forget the numbers, but the torsional strength of 3" tube is like exponentially better than even 2 1/2". I bet the engineers could explain it in detail.
    Tim D.
  6. Dale Fairfax
    Dale Fairfax
    And where, pray tell, did you ever find any "2 1/3" " tube? In fact, where did you even find a ruler that would measure in "thirds"? Did you mean "2 1/2" " or "2 1/4" "? If you used a dial caliper you may have seen 2.375 which is 2 3/8.
  7. Little Wing
    Little Wing
    from Northeast
    No Dale just a typo
  8. Old Rotor Flap
    Old Rotor Flap
    from Colorado
    I'd guess there's enough metal in the vertical sides of the Speedway bracket you referenced to cut a 1.25" radius out of it and still have sufficient structural integrity for a sensible size/weight motor.
  9. WelderSeries
    WelderSeries
    Alliance Vendor
    You could just radius the corners a bit and this should work fine:
  10. choppintops
    choppintops
    Chy, you still looking? if you are, pm me.
