Technical Front springs model a
Discussion in 'Traditional Hot Rods' started by David Knapp, Jun 25, 2018.
  1. David Knapp
    David Knapp
    Looking for a better ride for my 31 ford .I have Qa1 shocks on the front using the original springs with my set up ,its still a very bumpy ride I was told if I remove one leaf it will give my shocks a opportunity to work like they are meant to ,big question is witch leaf to take out ? Or does it matter which leaf to take out.
  2. Model A Gomez
    Model A Gomez
    I usually try to take out several leaves, you will need to make a spacer to take up the room in the crossmember so the u bolts will tighten up on the spring. While you have the spring apart you should bevel the ends of the spring on the bottom so they will slide better, I also put a light coat of grease between the leaves.
    flatford39 and dirty old man like this.
  3. Street Is Neat
    Street Is Neat
    I bougth rev. Eye main springs from "A spring "in Hartford Ct. Polished and grease . I took out number 3 and 5 .
  4. David Knapp
    David Knapp
    Thanks for the reply will give it a shot .
  5. David Knapp
    David Knapp
    Thanks for the reply .
  6. sdluck
    sdluck
    How many leaf are there in your spring,what motor and trans are in it,
  7. 1946caddy
    1946caddy
    from washington
    Size tires and air pressure? Is your shock setup correct for the weight of your car?
  8. sdluck
    sdluck
    More info please
    oldn_rusty likes this.
  9. sdluck
    sdluck
    This has been covered many times.
