Technical Front Suspension/Steering Questions
Discussion in 'Traditional Hot Rods' started by 30SportsCoupe, Aug 11, 2024.
  1. 30SportsCoupe
    30SportsCoupe
    Did I mention that my better half agreed to the purchase of this ride because it was a recent build and " needs nothing". o_O
  2. Unkl Ian
    Unkl Ian
    We won't tell her anything.
    clem and Bentrodder like this.
  3. Happydaze
    Happydaze
    On the possible relocation of the shock mounts and drilling holes..... the shock mounts look like SoCal pieces, which are stylized F1 mounts. These come with threaded bungs which require welding into the frame. I know some have found that these welded in bungs can fail. When I mounted mine I remade the bungs so they were longer and a little fatter. This enabled them to be welded not just at the outer face of the frame but also plug welded to the boxing plate and / or the horizontal surfaces of the frame. So much more than just nuts and bolts, and requires welding and refinishing, something I expect you're looking to avoid!
    Chris
  4. Happydaze
    Happydaze
    Just took this pic of mine. Parallel (ish) and aligned! I like shiney! Must swap the top nut on the shock!
  5. Unkl Ian
    Unkl Ian
    Yes, everything looks to be aligned correctly.
    Would it look better with the nut on the back ?
    An Acorn nut might be good.
  6. Happydaze
    Happydaze
    It has a forward facing stud coming out of the mount, and yes, an acorn nut is in the plan (but I'd forgotten about it till I took the pic!). From the front it's hidden behind the headlamp, hence why it has escaped my notice!
    Chris
    Unkl Ian likes this.
  7. Bandit Billy
    Bandit Billy
    I approve of your shininess.
    Happydaze and Unkl Ian like this.
  8. Unkl Ian
    Unkl Ian
    Ok, makes sense now. Don't know what I was looking at.
  9. 30SportsCoupe
    30SportsCoupe
    Thanks, I will take a look.
  10. 30SportsCoupe
    30SportsCoupe
    That pics help. I think if I can rotate the lower mounts I will be closer, maybe not great but better. I am going to end up taking the front end apart and reinstalling everything as suggested. Disconnect rear wishbone at the mount, remove the spring, add two leaves back to the spring and re install spring on axel, spring to frame and reconnect the bones. Hoping I can get everything to line up better. Early I said the lowercshock mounts weren't keyed. I was looking at some on line today and I see they have a keyway in the mount and you need to add apiece of key stock. I was looking for a slot at the bottom of the stem that the mount would key in to. Now I bet they are keyed, I will have to take a look. I am now considering installing hairpins, again after some web snooping I realize that the way the bones were cut to go under the tie rod is not the norm. I initially thought they just didn't have a pretty bead.
    Thanks all, I have a good bit of work to do.
    lothiandon1940 and Unkl Ian like this.
  11. Unkl Ian
    Unkl Ian
    Sounds like you are heading in the right direction.
    Also remember : The guy who assembled the front end, also did the back end.
  12. nrgwizard
    nrgwizard
    from Minn. uSA
    BTW, if you haven't already measured the bones mounting point on the frame, check that both sides are exactly the same length. This would effect the proper tierod end length(s) to keep the front axle properly aligned & each-side wheelbase the same. Might be pointless, esp since you're already checking everything else, but at least you'd know. & proper hairpins would solve more than a few issues there. Good base to start with there, you'll be happy when it's right("& she'll like it too". :D ).
    Marcus...
  13. deathrowdave
    deathrowdave
    from NKy
    Isn’t a car with cross steering in need of a panhard bar also? I’m kinda green on the answer , but I just moved a mount on an A with cross steering and it has a panhard bar . My 32 does not have cross steering so I have none .
    GlassThamesDoug and twenty8 like this.
  14. 26 T Ford RPU
    26 T Ford RPU
    That would be eliminated greatly with a shorter main leaf that would restore the correct shackle angle. But as it stands now.....yes. JW
    alchemy likes this.
  15. 26 T Ford RPU
    26 T Ford RPU
    This is the most true suggestion on this thread and any build like this... something to remember when you get someone else's work. JW
  16. Motoimpaired
    Motoimpaired
  17. clem
    clem
    I haven’t read every post, so excuse me if it has been mentioned.
    Whilst you are fixing things, consider cutting off the nuts to wishbones and weld in some correct bungs with a longer thread, as with a nut welded to the wishbone (and even if the wishbone is threaded) there is not much/enough engagement for the ball joint.
    26 T Ford RPU likes this.
  18. twenty8
    twenty8
    A panhard bar certainly wouldn't hurt.
  19. GlassThamesDoug
    GlassThamesDoug
    Keep after it.
    Caster and Camber on flat ground. I had lowered my front rake, and lost caster as a result.
  20. GlassThamesDoug
    GlassThamesDoug
    Absolutely if cross spring, that would be dangerous without.
  21. Ditch those big front tires, do some 5:60 x 15's or 6:00 x 15's with 1/8 in toe in and 6 deg caster and you should be OK. Balance the wheel and tire assy on the car with a dynamic balencer machine too, add the needed weights.
  22. RockyMtnWay
    RockyMtnWay
    Don’t want to add to your work list too much, but I would definitely add a gusset or two to the steering box mount.
  23. 2OLD2FAST
    2OLD2FAST
    from illinois
    Really doubt you'll have much luck finding an old on car balancer these days .
