Technical Front turn signals flashing
Discussion in 'The Hokey Ass Message Board' started by 32highboy54, Apr 1, 2014.
  1. 32highboy54
    32highboy54
    from southport
    Trying to wire my turn signal switch. My problem is my front turn signal wont flash one at a time. They both flash like I have my hazard flasher on. My turn signalsare a motorcycle type.When I got them it had only one wire.Would it be a ground issue with the turn signal.I have a rebel harness.
  2. 1971BB427
    1971BB427
    from Oregon
    Lack of a good ground will cause feedback through the wiring. I think your ground issue guess is spot on.
  3. Tudorp
    Tudorp
    I agree. If a ground is bad, the system will try to find a ground where ever it can and feedback through other systems and components. Electricity takes the path of least resistence so even if it is a loose, or corroded ground with high resistence it will cause some pretty funky electrical issues.
  4. bobss396
    bobss396
    Agree on grounds, make sure you have a 2-way flasher as well, not a 4-way hazard type. Swap around the bulbs, sometimes a bad bulb or even the socket can produce weird results.
  5. d2_willys
    d2_willys
    from Kansas
  6. sunbeam
    sunbeam
    Make sure some one did not put a single contact bulb in if they are also park lights.
  7. On my OT scout, a bad blinker setup in the steering column was causing random front and rear lights to flash and my brakes lights to not work at all unless I had blinker arm halfway up into the right blinker. Swapped the part out and never had another issue.
    This is a we'll known issue with grounds on the scout II's.
