Hot Rods front wheel cylinders
Discussion in 'The Hokey Ass Message Board' started by ags41dave, Aug 6, 2025.
  1. ags41dave
    ags41dave
    from midwest
    I blew a left front wheel cylinder on my 40 Willys the only ones available have a flat end on the piston were the shoe touches mine have a fork where the shoe touches this is on stock drum brakes I believe the cylinder was already a replacement as the backing plate looks modified I went to all the parts stores called the maker of the cylinder got nowhere so I ask have they decided that the forked piston is not needed and the shoe wont move around or do I remove the piston out of the new cylinder and try to put my forked ones in it the next move will be disks on the front if I cant get parts
  2. alchemy
    alchemy
    Buy some new cups and caps, hone the thing a little, and re***emble. The cups are usually a common size, not just Willys specific.
  3. Paladin1962
    Paladin1962
    You should post a picture of the style you need; some of us have been doing parts for years and might be able to get you fixed up. Need dimensions as well, mounting type, etc.
  4. RodStRace
    RodStRace
    dana barlow likes this.
  5. Johnny Gee
    Johnny Gee
    from Downey, Ca
    RodStRace and dana barlow like this.
  6. Paladin1962
    Paladin1962
    Volvo! Cheeky Swedes!
  7. RodStRace
    RodStRace
    I much prefer that makers use a standardized, proven design rather than building a new mousetrap that does the same job the same way.
    HemiDeuce and brading like this.
  8. ags41dave
    ags41dave
    from midwest
    thanks everyone I fixed them basically I took the ends out of mine cleaned and put in new cylinder and where as my line is a flared hard line now will not work because new cylinders are for hose fittings so at frame where hard line goes to a hose I put an adaptor on hard line other end accepts a braided metal line clips at frame then a different adaptor screws into cylinder other end accepts braided line then 20 in. steel braded line from frame adaptor to one in cylinder then as a reward I road tested over to the Rockabilly Ruckus and won an award for best g***er but best of all she stops again thanks again for the help; Dave
    Paladin1962 and RodStRace like this.
