Customs Front Wheel Drive Hot Rods
Discussion in 'The Hokey Ass Message Board' started by Frosty21, Jul 14, 2009.
  1. No, it cannot be FWD. As I stated in my first post, if it had any modern GM FWD transaxle in it, the engine would have to be between the headlights on that Cord. The Cord drivetrain was, basically, a conventional layout turned 180 degrees. This placed the front wheels, probably, 18-20 or so inches ahead of the flywheel, which is at the front on a Cord. The 4T60E trans is for a transversly mounted engine (See Pic). The engine in the Cord pictured is for and aft. If it has a 4T60E, there is some engineering in there that defies description.
  2. BEE-rad
    BEE-rad
    from mn
    what he said
  3. rodworks
    rodworks
  4. Kripfink
    Kripfink
    I can't believe that nobody has mentioned the Duefledo valve or the Gigglie fastener in this discussion yet.
    Paul
  5. R A Wrench
    R A Wrench
    from Denver, Co
    I have seen a couple that were well done. A Divco with GM fwd in Spokane at NSRA
    and a late 40's ? Buick with GM also, in the parking lot with the Hot Rod Road Tour. Both looked like great builds & very roadworthy. With the availability of newer fwd parts I think someone could put togather something pretty unique.
  6. Ned Ludd
    Ned Ludd
    Look again at the blueprint in my last post. I can't quite make it out, but the dimension from the front wheel centreline to the firewall looks an awful lot like 36¼". That scales well with some of the other dimensions that are a bit clearer. If the flywheel is 18-20" behind the front wheels the engine would have to be 16-18" long!
    I'm pretty sure the stock transaxle follows the Citroën DS pattern.
  7. The Cord trans is ahead of the axle centerline. As the picture shows, it is similar to a VW setup. Again, the 4T60E is for a transverse (sideways) mounted engine layout. The early Toro/Eldo trans was for a longitudinally mounted engine, but the halfshafts ran through the oil pan, so that setup won't work in a Cord either. Simply put, there is no modern GM FWD transaxle, that I am aware of, that has the same general layout and dimensions as a Cord, that is, engine sitting behind the transmission and sitting in the car in a conventional for and aft position. Perhaps a Corvair would work. Glen Pray used flopped Corvair drivetrains in his 8/10 Cords. A Crown adapter would allow a SBC to bolt up. Also, in the picture of the Cord, it seems to have a transmission hump
  8. Ned Ludd
    Ned Ludd
    Makes sense. Is that a preselector mechanism with all those copper lines?
    Those 80% "scale model" Cord replicas would have used Corvair drive trains exactly as installed in the Corvair, only at the front. I'm not sure about a sbc on a Corvair transaxle, though: don't they have a reputation for breaking differentials? As I said, Porsche 911: adaptor plates are available.
  9. Yeah, it a pre selector 4 speed transmission. It's the same box that Tucker used. I don't deny the possibility of a Porsche, Renault, Corvair, Wartburg or whatever trans being used to build a FWD hot rod. What I am skeptical of (does that make me a Luddite?) is the claim that the pictured Cord has a 4T60E GM transaxle in it. The engine is sitting the wrong way.......period.
  10. farna
    farna
    So it was just the much longer nosed L-29 (an early Cord, might have come out in 1929) that had the diff in front of the trans, the later models (mid 30s through the last... what, 1936?) had the diff between the engine and trans (ala VW Beetle) to make the drivetrain shorter.
    1979-85 Eldorado/Riviera/Toronado models used a longitudinal mount FWD trans similar to the earlier Elodo/Toro trans. 79-83 models are three speeds,84-85 four speed. 65-78 models used the THM425, based on a TH-400.
    I've seen many auto carriers built from 4x4 trucks and car trailers. Basically the trailer tongue is cut off and the 4x4 pickup frame grafted to the trailer. The T-case in the truck is locked in 4WD so that the front wheels are driven. Not worth a hoot on dirt or gr***, but fine for highway transport, and the loading bed is very low.
    Most of the hot rods that I've seen using a FWD drivetrain have the wheels locked straight and the drivetrain in a mid engine position. One of the 79-85 or earlier Eldo/Toro packages might be made to look right in something like a traditional 32 body, but would be better in something wider like a late 30s/early 40s car. Come to think of it I have seen one of those in the front of a late 30s car... 38 or so GM I think... can't remember when and where though.
  11. metalshapes
    metalshapes
    I totally agree...
    But there are some racing conditions where Front Wheel Drive is usefull.
    '60s Mini Coopers and 2 stroke Saabs did well on the snow covered Monte Carlo rally stages.
    And I volunteered a lot of time to help build this 2000HP turbocharged Front Wheel Drive Berkley for LSR racing at Bonneville.
    ( I beleve its setting records now...)
  12. farna
    farna
    FWD isn't traditional by any means, doesn't mean it can't be a hot rod though. That green car isn't practical at all, but only because of the rear steering. If a 4x4 front axle had been used instead it would still be just an interesting concept, but would at least be drivable.
  13. Ned Ludd
    Ned Ludd
    True. Front-drivers unload their driven wheels under acceleration, which is why one doesn't want front-wheel drive on a hot rod. On the salt that kind of weight transfer isn't really an issue: traction vs aerodynamic drag is pretty much the same problem regardless of which of the wheels are driven.
  14. farna
    farna
    Correction Ned: That's why someone doesn't want FWD in a DRAG CAR, not necessarily in a hot rod. While I think most people do want rapid take-off in their hot rods, not all do. If it's mainly a touring car FWD wouldn't be an issue. And FWD CAN be set up to run straight line pretty well. There was a turbo Honda on Pinks a couple years ago that was running down traditional rear drive cars. Big turbo and slicks on front. Everyone got him out of the hole, but around the 1/8th mile mark he had caught them and was running away. He just took it easy coming off the line and ran everyone down.
  15. metalshapes
    metalshapes
    The problem with the salt is that it doesnt give much grip.
    And because the condition of the salt had been getting worse, because of the mining, the car that came before the Berkley had trouble putting its power down.
    It spun out a couple of times, and we tried to make it more stable by trailing a tiny parachute that Deist made for us, etc.
    The Berkley was built to try and solve those problems.
    Longer, FWD, and a lot of front weight bias.
    This thing wants to go straight...
    ( and if you spin the front wheels it doesnt spin out the car )
    Other than that, I've driven FWD on the street and on racetracks.
    I dont like it.
    It doesnt suit my driving style...
  16. How about this one, it's a Henry J on a 1987 Chrysler LeBaron turbo floor pan
    tonymonroy likes this.
  17. scootermcrad
    scootermcrad
    Couple weekends ago I acquired a "little" pages magazine on hot rod ch***is and suspension. Date would have been around '58 or '59 maybe even earlier, based on the other mags he had, (cover was missing) and it was FULL of stuff that everyone has been saying is "not traditional"!!! Including some front wheel drive applications. Unfortunately it didn't go into detail, but did allude that components could be had from European donor cars.
    It also mentioned that it was becoming popular for lakes racing.
    I've been thinking that one day I would like to try an all wheel drive arrangement just for the hell of it using all "traditional" parts. Nothing new...
  18. metalshapes
    metalshapes
    Bugatti built a 4 wheel drive car in 1932, Spyker built one in 1903.
  19. metalshapes
    metalshapes
    John Walter Christie built several front wheel drive cars around 1910, and there were some FWD racers at Indy.
    Other than that, it didnt really get popular untill Alec Issigonis found a way to put all the oily bits in one spot to give the p***engers more room and people like Ralph Nader decided for us that an understeering pig of a car is a safe car...
  20. scootermcrad
    scootermcrad
    Yep! Nothin' new here...
    Were some of the Millers also 4 wheel?
  21. metalshapes
    metalshapes
    Yep.
    Another thing that made the FWD system more practical was the invention of the Rzeppa Joint.
    ( what we now know as the Constant Velocity Joint, or CV Joint)
    Regular U Joints in driven & steering front wheels have aways been a poor compromise...
    Invented sometime in the '20s, but not practical to produce untill the '50s or '60s.
  22. scootermcrad
    scootermcrad
    Cool! Good info! And the CVJ was a wonderful invention!
  23. farna
    farna
    Someone mentioned FWD didn't suit their driving style. That's a big one! FWD does demand a different style of driving. First one I drove was a 74-75 Honda Civic as a teen. Dad got one of the first few in South Carolina. It definitely drove different, but I quickly learned that hanging the rear end out on dirt roads wasn't an issue, as long as you didn't hang it out so far you couldn't counter steer! Knowing the car was going to go where the front wheels pointed was a big plus. Not always so with RWD... some cars will "plow" a bit if going into a curve too fast on skinny tires (thinking about my first Rambler that I put factory size bias plies on the first time I got tires.... never again though!!). Of course I'm talking factory original cars, hot rods are usually improved a bit in the steering/tire department, especially if meant to be driven aggressively in anything but a straight line (won't talk about T's with skinny tires up front...).
  24. Ned Ludd
    Ned Ludd
    Indeed. I've had almost only front-drivers, the two exceptions both being older cars. My current DD VW Golf Mk1 is quite a roller-skate on slightly-modified suspension and a 195/50-15 Yokohama/Pirelli combo, but I do miss being able to tighten a line with power. And lifting the left front accelerating out of a roundabout might sound impressive, but it isn't very effective!
  25. Didn't see it mentioned here, but the Miller front wheel drive layout was essentially the drivetrain that was adopted for the Cord. I think I saw at the Auburn museum that Cord bought the plans directly from Miller.
    The front of those Millers are truely beautiful.
  26. Ned Ludd
    Ned Ludd
    For the L29, yes. That is, diff-gearbox-clutch-engine. The later Cords we have established were gearbox-diff-clutch-engine.
  27. cheapracer
    cheapracer
    from China
    https://www.kustomrama.com/index.php?***le=Reactor
    From 8.08 minutes ..
    I am here due to Google search criteria "FWD Hot Rods" linked to this thread, because I am developing a 3 wheeler right now, Morganish, but FWD more in line with the Vanderhall ...
