Technical Frozen converter woes
Discussion in 'The Hokey Ass Message Board' started by 66GMC GUY, Aug 18, 2026.
  1. 66GMC GUY
    66GMC GUY
    I need to tap into the collective knowledge of the brain trust here. I picked up a 200-4r a while back, that I recently decided would be nice to rebuild and drop into my 59. So I went to pull the converter and set the trans up on my stand to begin tear down. Thats when I discovered a most unfortunate development: the converter was stuck. Not just stuck as in hard to remove, but stuck to the point it appears to have become one with the rest of the trans. I started off with the standard "twist and pull" method by hand. This escalated to the ever popular "try and walk it off with a pair of pry bars" which led to a board across the bellhousing with bolts to try and pull the converter outwards. This finally led to the (failed) method pictured. The teal truck wound up being dragged backwards, still in gear, and with the wheels blocked. Im working out of my home garage with largely basic tools. Anyone have any quality suggestions on how to get this monster removed? Snapchat-292819075.jpg
    leon bee and anthony myrick like this.
  2. Might be time to get out the ol' flame wrench...
    Bandit Billy likes this.
    Step one: bolt converter to chain and attach chain to truck hitch
    Step two: Secure trans to something heavy
    Step three: Remove converter by pulling foward with the truck in step 1.
    lostn51, leon bee, Just Gary and 2 others like this.
  4. Bandit Billy
    Bandit Billy
    ATF burns. Don't ask.
  5. 66GMC GUY
    66GMC GUY
    My concern there is setting the fluid on fire....
    leon bee and 19Eddy30 like this.
  6. I’ve seen 2 pry bars used just be carefull of the case
    sidevalve8ba and leon bee like this.
  7. 66GMC GUY
    66GMC GUY
    I had it strapped to my 66 pickup, and was yanking on it with my daily. No dice. Though I'm amazed that the ratchet strap holding the case didnt snap with as much as I was pulling.
    anthony myrick likes this.
  8. Get a heavier truck
    66GMC GUY likes this.
  9. 66GMC GUY
    66GMC GUY
    Might have to rope the neighbor into my shenanigans again.....
    Just Gary and anthony myrick like this.
  10. ClayMart
    ClayMart
    Gives new meaning to the term "locking torque converter". You may have to track down a real old-school locksmith. :confused:
  11. Well, I didn't say that it might not get exciting... Drill some holes in the convertor to get the ATF out first.
    And you'll probably have better luck if chains are used on both ends of the pull. Then again, that may knock some corners off the case.
    leon bee and 66GMC GUY like this.
  12. 66GMC GUY
    66GMC GUY
    Honestly I was surprised at how well that strap was holding up. Prefer not to damage the case if possible.
  13. Before you damage the case, make a fixture to bolt to the ears on the converter. Make and attach a heavy slide hammer out of a piece of pipe (I have one full of sand to add weight) One person on each end of the pipe will ease that converter out of the front pump. You may want to leave the trans attached to your truck while using the slide hammer.
  14. RodStRace
    RodStRace
  15. tomcat11
    tomcat11
    A big slide hammer is your best bet. You could take it to a transmission shop to see if they have one or they might just say it's junk. Probably welded itself to the pump.
  16. SS327
    SS327
    Try unbolting the front pump and pulling it all out together. The pump is probably junk anyways.
  17. 66GMC GUY
    66GMC GUY
    Guilty as charged :D I expect the pump is trashed, but I planned on a full rebuild so I'm not overly concerned.
    Surprisingly the shops I've called wont touch it. Most just say they would pitch it and swap in a new unit which is baffling to me.
    Ive thought about that. Can the pump bolts be fully removed with the converter in place, or are they too long?
  18. RodStRace
    RodStRace
    When two parts love each other and mate up, it affects all the other parts in their immediate vicinity. The heat, bits of metal and such may not all get found, and it's not worth the effort on a common, cheap unit. Especially true if you need another core for some of the parts.
    If it was a rare HAMB era part, it would be the only way forward and the extra time, effort and risk would be spent. On something where another core can be delivered and torn apart, why risk it? It's why those same shops won't redo a 1950's Hydro. Time and effort to track down parts, fully inspect and rebuild using only the single unit's bits. Any issue with wear tolerances, debris or damage must be fixed. Even more time, effort and risk. They can't do a 'farm fix' where it's back on the road for a while. It's got to be fully repaired to the best possible. Ask any long time shop about "just get it patched" repairs. Every one will have a horror story about helping someone and getting bit for their effort.
    SS327 and leon bee like this.
  19. justpassinthru
    justpassinthru
    I have had maybe one handful of converters in 45 years of building transmissions, that would not come out .
    Sometimes beating, prying, pulling and other creative ways just don't work.
    Most have been everyday transmissions and just s****ped them and got a core.
    One was a Buick Dynaflow, that we had no option but to figure a way to remove the converter as there were no cores available.
    Eventually got it out of the trans with a lot of blood, sweat, tears and cussing.
    Converter hub, pump, input shaft destroyed.
    Good luck
    Bill
    RodStRace likes this.
  20. tomcat11
    tomcat11
    If you can get a wrench on the bolts you can loosen them some, pull on the converter/pump, loosen some more, until hopefully it all comes out. Maybe.
    SS327, Budget36, 66GMC GUY and 2 others like this.
  21. 19Eddy30
    19Eddy30
    from VA
    Like other's said
    I would drill some holes drain as much fluid out , start with cut off wheel
    Remove internals of converter
    then shell to remove pump .
    Maybe a fire but needs to be done .
    @ this point looks to be taken chance braking case , pump threads
  22. warhorseracing
    warhorseracing
    from cameron wv
    16 Lb. sledge hammer.:eek: Have some fun letting out your frustration.:D
    Budget36 likes this.
  23. JD Miller
    JD Miller
    "Hold my beer and watch this !"
    :D
    warhorseracing and 66GMC GUY like this.
  24. 66GMC GUY
    66GMC GUY
    Might give this method a shot. Im sure i can probably cut and fold enough to at least get the pump out and make it easier to work with....
    SS327 and warhorseracing like this.
  25. 66GMC GUY
    66GMC GUY
    I opted for violence and cut it out. The hub is still very stuck in the pump, but hopefully I can get that apart as a separate en***y once it comes out of the transmission. 20260825_112135.jpg 20260825_112146.jpg 20260825_112135.jpg 20260825_112146.jpg 20260825_112150.jpg 20260825_120335.jpg
  26. ronzmtrwrx
    ronzmtrwrx
    And I thought I was the only one that **** like this happened to. Way to persevere though. You’re going to win this fight.
  27. 66GMC GUY
    66GMC GUY
    Man it's almost the norm for me it feels like.
    SS327 likes this.
  28. ronzmtrwrx
    ronzmtrwrx
    You’re not alone. :cool:
    SS327 likes this.
