FS: 1951 Shoebox Ford - full air ride - sbc - thm350 - 4 whl discs - 8" r/e
Discussion in 'Cars For Sale' started by slammy, Feb 10, 2016.
  1. slammy
    slammy
    City: Thousand Oaks
    State: California
    Price: 12,000
    1951 Ford Two Door Sedan
    VIN Number 00B1SP156111
    I’ve sunk over $24K into this car. I have a summary of all my receipts, and have scanned them all and can email this file to serious buyers. 2 kids and a demanding job force me to move it along. It's yours to finish. Hard work is done. All work done by Matt Noble of Noble Fabrication in Ventura, CA
    Pics: share.shutterfly.com/action/welcome?sid=0QbtmzZu5ZOHHA
    · Powertrain: 350 Small block chevy + 350 Turbo auto trans w/ Gennie Shifter
    · Suspension: Complete Air Ride system – lays frame and front cross member on ground
    o 4 bags and mounts
    o 4 new shocks and mounts
    o 2 480C Viair pumps (200 PSI)
    o New 5 gal tank
    o 7 switch box
    o 30 amp relays
    o Custom wire harness for air ride system
    o 4 x 200 PSI 3/8” manifold valves
    o 50’ of 3/8” 200 PSI air lines
    o Custom rear 3-link bar set-up w/ adjustable panhard bar
    o 2.5” C-notch on frame and custom body cut-out for pumpkin clearance
    o Dakota Digital air ride gauge
    o Fatman II dropped uprights
    · Running gear:
    o New drive shaft (Coast Drive Line and Gear – Ventura, CA)
    o 8” Ford rear end w/ new bearings and axels (Coast Drive Line and Gear – Ventura, CA)
    · Braking system: Complete, new 4-wheel power disc brake system (4x discs w/ new calipers, discs, lines, dual chamber master cylinder and booster) (JAMCO)
    · Exhaust: Full new exhaust system from ram’s head manifolds back to rear bumper (full dual w/ glass packs); sounds great. Pipes “rap” perfectly.
    o Exhaust was custom done after airride system install; carefully routed not to interfere w/ travel of suspension.
    · New wheels
    · New tires (Diamond Back Classics)
    Custom Work:
    · Custom peaked hood
    · Frenched headlights (51 Merc rings from Night Prowler) (unfinished)
    · Frenched taillights (unfinished) (Night Prowler buckets)
    · New Mustang II 22 gal fuel tank; new fuel lines and pick-up
    · New battery box w/ gel core battery
    · New 12 volt harness
    · Fully converted and rebuilt original gauges to 12 volt (Redline Gauge in Santa Clarita, CA)
    Refurbish Work:
    · Remove and re-hang driver and passenger door w/ all new hinges
    · Repair driver and passenger A-pillars;
    · Rebuilt Carb
    · Full Tune (new manifold gaskets; new valve cover gaskets; new distributor vacuum module)
    Extra parts:
    · 1953 Chevy grille w/ 7 teeth
    · Extra set of interior and exterior (stainless) window trim
    · Interior trim panels
    Work Needed:
    · Finish removal of drip rails
    · Finish seaming of rear fenders
    · Finish frenching headlights and tail lights
    · Misc body work (front and rear aprons)
    · Fenders, body mounts, rockers and mounts need repair or replacement – extensive (rust and bad sheetmetal work)
    · Rear seat
    · Interior
    · Trunk Firewall
    email: samgasowski@gmail.com
    text: (805) 300-2998
    It's on eBay, but I will end early for a HAMB buyer
