Technical Fuel cell leak
Discussion in 'Traditional Hot Rods' started by old trucke, Oct 18, 2024.
  1. ronzmtrwrx
    ronzmtrwrx
    True. This particular tank cracked right above the angled mounting bracket that was welded to the side of the tank. It bolts up under the frame and just hangs there. 20 gallons is a lot of weight pulling on those mounts. I added some gussets below the angle to try and help spread the stress, but I’m not sure that it won’t happen again. The owner had put rubber between the frame and mount, but I’m thinking any slight frame flex may have contributed to it cracking.
  2. 29Sleeper
    29Sleeper
    from SoCal
    Won't work with new gas the additives and alcohol eat the FG.
    Let's get the definition right here. This is not a "fuel cell" it's a gas tank. It's easy to fix. Just purge the tank with the same inert gas you will be using to weld the aluminum. Like others have pointed out remove the oxygen.
    PS - a fuel cell is a flexible bladder generally contained within a metal or plastic housing.
  3. 2OLD2FAST
    2OLD2FAST
    from illinois
    Screenshot_20241024-171843.png Screenshot_20241024-171627.png Years back we would solder tanks with a soldering IRON , either electric or heated on a burner , nothing particularly unsafe about it . Screenshot_20241024-171627.png
  4. squirrel
    Works on steel tanks, but not so good for aluminum, unfortunately.
  5. Probably so! I would try anyway. Especially if the leak is in a seam. Try J.B! Little money wasted. And will PROBABLY out last the poster.
    Ben
  6. 2OLD2FAST
    2OLD2FAST
    from illinois
    Thank you capt obvious ...LOL ...:D
  7. squirrel
    well, when you post that on a thread about fixing aluminum tanks, I just gotta wonder! :)
  8. 2OLD2FAST
    2OLD2FAST
    from illinois
    Oh boy ....:rolleyes: ...
  9. 19Eddy30
    19Eddy30
    from VA
    I think , & I am not a engineer ,
    Its how the tank is made & where its welded , My aluminum 7 gal tank was made using a bulk to form & roll all edges 1/4 - 1/2 like stamped , seams where welded above not @ 90s ,
    I think also not enough
    bracing / gussets do to vibration cause the cracks @ weld steel & aluminum.
    ronzmtrwrx likes this.
  10. G-son
    G-son
    from Sweden
    The problem with gas leaks is that gas is flammable and if the gas happens to be ignited the wasted money can be the value of the entire car, possibly including the garage you just parked in and the house right next to it. A proper repair isn't expensive.
  11. 19Eddy30
    19Eddy30
    from VA
    Does any one Else think what could happen when adding Petro into any tank the fumes!
    All it takes is small static spark
  12. 2OLD2FAST
    2OLD2FAST
    from illinois
    Nope , have more pressing issues to think about .
    firstinsteele likes this.
  13. Rather than mounting aluminum fuel tanks off the side-mounted tabs, couldn't they/ shouldn't they maybe be mounted using straps, not unlike how car tanks were/are typically mounted?
    My old plastic fuel cell was mounted using straps top and bottom. Just because a tank comes with mounting tabs doesn't mean it's the best method for installation.
    2OLD2FAST and Althebass like this.
  14. ronzmtrwrx
    ronzmtrwrx
    I didn’t build the vehicle that this tank came off of, (64 Suburban) but yes, straps would have been a much better option.
