Fuel gauge adjustment??
Discussion in 'The Hokey Ass Message Board' started by solo_909, Jan 12, 2014.
  1. solo_909
    solo_909
    Hey guys so I just put in a new fuel sending unit from early ford parts and filled up my tank. My gauge is reading at 3/4's full when it's filled to the top. Can the fuel gauge be adjusted to match or is there an issue with something else?
    Thanks,
    George
  2. saucerhead
    saucerhead
    To the best of my knowledge, you will have to adjust the float, and or float arm. Sounds like the length or angle is off.
  3. solo_909
    solo_909
    Hmm, I did it to the exact specs and measurements that was provided though.
  4. dirt t
    dirt t
    Check and make sure you have a good ground.
  5. solo_909
    solo_909
    That's the strange part the unit worked without the ground. I hooked one up anyways and it didn't change anything.
  6. ROADSTER1927
    ROADSTER1927
    Take the sender out of the tank, then with it hooked up cycle it to full and empty and watch the gauge. If your gauge goes all the way to full and empty then you have to bend the float arm until it can do that in the tank. If not the sender is either bad or your gauge and sender do not match! Gary
  7. solo_909
    solo_909
    Perfect, I'll give that a try. Do I bend the float up or down?
  8. ROADSTER1927
    ROADSTER1927
    Measure the depth of the tank and bend the rod until it clears the top and bottom of the tank a little bit.:D Gary
  9. solo_909
    solo_909
    Cool, I appreciate it!
