1952-59 Ford Fuel gauge pegged on full
Discussion in 'Off Topic Hot Rods & Customs' started by dodg66440, Jul 11, 2025.
  1. dodg66440
    dodg66440
    56 Customline. Started the car to go run an errand and noticed the gas gauge is showing a bit above full. Was working fine the last time I drove the car. Where do I start looking?
  2. Paul2748
    Paul2748
    Does the gauge go to empty when the key is off? If so, the gauge is probably ok. Then go to the sending unit. First, get a separate wire and ground the sending unit it to a good metal spot. Maybe it is just a round problem. If that does not help, pull it and work it manually (remember to ground it while out). See if the gauge will work. If no dice, you might try a wire from the gauge to the sender to see if there is a break in the old wire.
    dodg66440 likes this.
  3. abe lugo
    abe lugo
    Pull the sender and see if it sticking in the full position. Work it back and forth to loosen it a bit.
  4. Texas57
    Texas57
    Tanks Inc has a really good troubleshooting guide on gauges not working correctly. Probably a grounding issue.
    down-the-road likes this.
  5. JeffB2
    JeffB2
    from Phoenix,AZ
  6. marlinmustang
    marlinmustang
    from Nanuet NY
    Full indicates the sending unit is grounded. Either the sender is bad or the wire to it is touching the frame. Pull the wire off the sender and see if it goes to empty. If it does your sender is faulty. If not then pull it off the gauge and see if it will go to empty. If not the gauge is shorted. If so the wire is shorted. .
  7. JeffB2
    JeffB2
    from Phoenix,AZ
    Since you have a 1956 you may have a problem solving this, Ford went back to using Six volt gauges in 1957 up till the early 1980s by using a gauge regulator. Tracking down a 1956 one year only gauge or sender might not be fun, good luck.
    nosford likes this.
