Fuel Guage
Discussion in 'Questions & Suggestions' started by 534door, Sep 26, 2005.
  1. 534door
    534door
    from coquitlam
    My 53 has been converted to 12 volt and I noticed that the wire to the gas guage sending unit has been cut off before I got the car. Should it be o k as I have the amp and the oil pressure guage hooked up now.( it has a 350/350) in it and its a pain in the *** not having a gas guage.
    Thanks:D:D
  2. Yo Baby
    Yo Baby
    You will need to use a resistor and dash voltage regulator to lower and maintain consistent voltage for the instrument Ie fuel gauge.The ammeter and oil pressure gauges don't know come here from sick 'em in your case.
    But most of all you need to post the question in the correct forum to get a good response.
    T.OUT
  3. 534door
    534door
    from coquitlam
    would like to but it says I don't have access???????:(
  4. Rocky
    Rocky
    Classified Editor
    Hmmmmmmmmmm...another guy with no access...must be going around.
    Check the post I just submitted regarding the same problem with another member..maybe the answer to his question will help you.
    Rocky
  5. 534door
    534door
    from coquitlam
    It doesn't help.
    It just says that I can't access that forum. Maybe too much of a nube.:D:D
  6. Paul
    Paul
    Editor
    if by "that forum" you mean the Tech Archive,
    that's an archive, not an open forum.
    technical questions are asked on the main board.
    this forum is for questions about how the HAMB works..
    which in a back ***wards way has just happened here.
