Technical Fuel Line Heat Shield
Discussion in 'The Hokey Ass Message Board' started by Steves46, Nov 29, 2015.
  1. Steves46
    Steves46
    from Florida
    Since I am running dual exhaust, there is about 18 inches of metal fuel line running close to the exhaust which may be contributing to the occasional vapor lock hiccup that happens after being stuck at a long red light. Would a rubber fuel hose slipped over the metal line serve as a decent heat shield?
  2. Tony
    Tony
    It may help, but there is really nothing deflecting the heat, just something insulating the line.
    If there were no room for a small tin shield to be made and mounted with a little room between the line and shield, id get some heat reflectant tape and wrap the line with that, or use the hose and wrap the hose in it which may offer more protection and a sort of insulator.
    The tape im thinking of has been used for years by auto manufacturers around electrical components near heat sources. I've used it a few times on my builds with good luck.
    Always seems to protects the wires quite well and i imagine would do the same for a fuel line.
    Tony
  3. hotrod mike
    hotrod mike
    DEI makes some very nice heat shielding products. I've used them and been happy with the results.
  4. Steves46
    Steves46
    from Florida
  5. Bugguts
    Bugguts
    I used a pipe insulation that I got at a heating and cooling business. They just gave it to me as it was s**** to them. It's foam and has a tinfoil like outer on it. Been working for 20 plus years.
  6. 3banjos
    3banjos
    from NZ
    Have used a short piece of stainless body molding spear. Couple of fabbed brackets to hold in behind your line clips.
    More a shield or deflector than an insulation. Worked fine
  7. Brand Apart
    Brand Apart
    from Roswell GA
    DEI has good stuff as hot rod mike said. You can get creative with their products too. I use the sleves on fuel lines and I took their starter heat shield and modified it to cover an electric inline fuel pump.
