Fuel Line Question
Discussion in 'The Hokey Ass Message Board' started by Crash, Jul 23, 2009.
  1. Crash
    Crash
    from Poplar, WI
    I m wondering what i need to do about my return fuel line. I have a 350 Olds motor in my 49 F1. Im running the stock fuel tank. The fuel pump has the line from the tank to the pump, pump to carb, and then one other (i ***ume a return). Can i block it off, or do i need a diff pump?
    Thanks.
  2. Dirty Dug
    Dirty Dug
    If you're running a mechanical fuel pump you don't need a return line.
  3. squirrel
    I'd get a different pump...
  4. kwoodyh
    kwoodyh
    Cap it off, should be no prob, when it needs changed get one with only an inlet and outlet.
  5. squirrel
    wouldn't hurt to check pressure to the carb if you cap it off....
  6. Crash
    Crash
    from Poplar, WI
    Ok, thanks. I was goina just cap it off, but didnt know if it built up pressure...
  7. Crash
    Crash
    from Poplar, WI
    so i finally fired the truck up, and its definetly spraying gas... guess i have to get a new pump...
