Hot Rods Fuel line running high up under dashboard?
Discussion in 'The Hokey Ass Message Board' started by Fredy, Feb 10, 2024.
  1. Fredy
    Fredy
    I just bought a 1940 Ford Convertible with a mildly souped up Flathead motor. For some reason the gas line, after leaving the electric fuel pump, comes up through the floor and runs behind the driver side kick panel. It then goes high up under the cowl, does a couple of loops with neoprene hose before heading back down through the floor and on to the regulator, stock fuel pump and to the dual 97's. Anyone know of a possible reason for running the gas line this way? Seems like a pretty dangerous idea.
    Unkl Ian and 427 sleeper like this.
  2. Jmountainjr
    Jmountainjr
    Not sure why, but you need to get the gas line out of the p***enger compartment.
  3. AVater
    AVater
    Seems pretty sketchy. I'm guessing the neoprene hose is for extra safety:eek:.
    olscrounger and Unkl Ian like this.
  4. Fredy
    Fredy
    I agree 100 % but I just want to hear a possible reason why someone would do that in the first place?
    Unkl Ian and Tow Truck Tom like this.
  5. krylon32
    krylon32
    from Nebraska
    I'd dam sure reroute the line outside the p***enger compartment for safety. Never heard of that before?
    olscrounger, Unkl Ian and SS327 like this.
  6. goldmountain
    goldmountain
    That thing sort of works with an EV.
  7. 05snopro440
    05snopro440
    Someone thought they had a smart idea? Sounds like bad news to me
    Tow Truck Tom and Unkl Ian like this.
  8. pprather
    pprather
    Builder wanted a high point, above tank and carb, so fuel could not flow back toward tank when engine/pump is shut off?
  9. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    When gas was iffy and running times in hot traffic was more,,,
    crazy things were used to reduce fuel temp ( vapor lock )
    Other than that, the guy was a nut
    o_O
  10. Fredy
    Fredy
    Sounds like a possible reason but why not just switch on the electric pump for a few seconds instead of going through all that trouble?
    Unkl Ian likes this.
  11. TA DAD
    TA DAD
    from NC
    He must have been a NASCAR fan, they run the fuel line through the car. I am surprised how many on here run the fuel line on the driveshaft side of the frame and have fuel lines mounted on the fire wall. But yeah that is about the worst idea I have heard of.
  12. Dooley
    Dooley
    from Buffalo NY
    How did the heaters back then work?
    Didn't they use fuel line for them inside the car?
    40FORDPU and Billybobdad like this.
  13. bill gruendeman
    bill gruendeman
    Rubber fuel line on the pressure side of the pump in the p***enger compartment, what could go wrong?
    Hose leaks and sprays fuel in your lap, please fix it BEFORE you drive it.
    olscrounger likes this.
  14. lumpy 63
    lumpy 63
    I seem to remember that there were gasoline powered accesory heaters back in the day, mostly a VW thing?
    '34 Ratrod, Unkl Ian and SS327 like this.
  15. Dooley
    Dooley
    from Buffalo NY
    I had one in a 46 Ford
  16. nrgwizard
    nrgwizard
    from Minn. uSA
    Probably wanted a fuel-pressure gauge inside where he could see it while engine is under load at various speeds.
    Marcus...
    X-cpe likes this.
  17. Rickybop
    Rickybop
    The seller feels that you drove his price down too far, so he thought it might be funny to see you do a Daffy Duck / Wile E. Cyote impersonation?
    Tow Truck Tom likes this.
  18. Oneball
    Oneball
  19. RmK57
    RmK57
    Something that was supposed to be temporary to read fuel pressure as mentioned, but turned out more permanent. I’d change it asap or put up no smoking signs inside the car.
  20. Johnny Gee
    Johnny Gee
    from Downey, Ca
  21. BJR
    BJR
    People do stupid things all the time. Just fix it and make it safe and move on. :D
    Blue One, Tow Truck Tom and bchctybob like this.
  22. Hondas in the 80’s ran the fuel and brake lines in the car under the carpet on the floor . One continuous metal line .
    I owned a winter beater where is rusted out and got a pin hole leak .
    stupid design then , stupid in your car as well .
    That chance of failure may be slim , but it’s not zero .
  23. Unkl Ian
    Unkl Ian
    Dumbest Idea of the Day Award winner.
    olscrounger and Tow Truck Tom like this.
  24. I know you're just wondering why, so I'll ask if the line is spliced in the p***enger compartment? May have had pressure gauge, or primer bulb in there, for operator access with whatever engine at the time. Then removed, just continued the line to the engine, or the replacement engine with proper fuel pump on it.
  25. Fredy
    Fredy
  26. Fredy
    Fredy
    Sounds like a good theory! It is 5/16" copper tube coming in and up connected without the use of hose clamps to a double loop of 5/16" hose and then back down with another 5/16" copper tube through the floor.
  27. X-cpe
    X-cpe
    Seller did it just to drive the new owner crazy.
    Tow Truck Tom and VANDENPLAS like this.
  28. Fredy
    Fredy
    I sure will "Fix it" I just wanted to share and hear back different theory's!
  29. flynbrian48
    flynbrian48
    Yeah, well, a moment of thought should make it obvious why running gas lines to an in cabin heater, might be a bad idea. People did it, yes indeed, that doesn't mean installation was always up to par, fittings could loosen, lines could crack, next thing you know, your lap is on fire.
  30. davidvillajr
    davidvillajr
    so, either way, it keeps you warm. :D
