Technical Fuel mileage
Discussion in 'The Hokey Ass Message Board' started by Racer29, May 25, 2017.
  1. gimpyshotrods
    gimpyshotrods
    I challenge anyone getting that poor mileage to let me put an O2 sensor in a collector or downpipe, and let me show them.
    In all of my tuning time using a wideband Oxygen sensor, I have NEVER had a vehicle come in, no matter how good it ran, or how fast it was, that was tuned properly, by "feel".
    My best to-date has been a 3.11x increase in freeway fuel mileage.
    That car ran great when it came in. According to the customer, anyway.
    Hot rods are supposed to foul plugs, right?
    I never did check the before and after mileage of the mild SBC 350 who's owner put on a 1050 Dominator.
    Truck64 likes this.
  2. squirrel
    Oh, I get decent mileage out of mild 350s. It's the quick cars that don't do so well. And yeah, I've had a wideband on the carbs (on a different motor), pulls about 13 afr cruising.
  3. squirrel
    Does this look fouled? been in there about a year, I think....that's well over 2k miles.
  4. das858
    das858
    With my 1938 Plymouth pick-up I get over 19 mpg on the hiway all the time, occasionally over 20 mpg when the wind is right. 360 4 barrel, 5-speed manual x-15, 3.23 rear gear. IMG_2130_12fc_0-1.jpeg IMG_2112_NsUv_1.jpeg
    fourspeedwagon and Montana1 like this.
  5. Fuzzy Knight
    Fuzzy Knight
    from Santee, Ca
    306 SBF Alum Heads 2 600 Holleys
    16 @ 70 mph
    zip in town
  6. Chiss
    Chiss
    from S.C.
    Just a Hobbyist, but putting 900 or 1000 CFM on 3 or 400 H.P. motor will kill any kind of Fuel mileage. Over Carburation is the no. 1 killer of Power Torque and Fuel Effiency.
    gimpyshotrods likes this.
  7. I dunno My 66 GMC with 250 six and 336 rear gears don't seem to guzzle gas. My OT 86 chev 3/4 ton with 350 2 bbl likes fuel. Put a load on it or behind it and it really guzzles the gas. Ive never owned a 350 that didn't guzzle gas. I wish the 86 truck had a 305 V8 or a 250 six. However its not any problem for me to afford gas at present. When I was younger sometimes I couldn't afford to fill the tank.
  8. Ive owned a few of those V6 GMC engines and they got a wopping 4 MPG and didn't puff any black smoke or foul sparkplugs. They would pull any load you wanted hardly ever has to downshift on the grades. anywhere from 305 cu in to 478 cu in 4 MPG was the best I ever got.
    Bill's Auto Works and hendelec like this.
  9. Fuzzy Knight
    Fuzzy Knight
    from Santee, Ca
    Now I really don't care about the mileage so much. I have taken steps to improve it somewhat but I'ts a Hot Rod so I really don't care. He asked so I responded.
  10. junkyardjeff
    junkyardjeff
    If I had a real hotrod gas mileage would not be the top priority but since I do drive a couple long distances I do have to think about it since I do not have a money tree in my back yard.
  11. squirrel
    My wife and I planted a money tree many years ago, it's nice to have....especially when you drive something that gets 7 mpg
    hipster and olscrounger like this.
  12. junkyardjeff
    junkyardjeff
    I need to know where you get them since they can not be found up my way.
  13. squirrel
    Gotta plant them when you're young.
    31hotrodguy and hipster like this.
  14. junkyardjeff
    junkyardjeff
    Too late now.
  15. gene-koning
    gene-koning
    Last week, 1300 miles, 21.8 total mpg. I've also discovered my odometer is registering 7.5 miles for every 10 miles traveled, according to those little markers on the Interstate.
    I should probably recheck my numbers, mileage is probably better then I thought.
    Its probably a wonder I haven't gotten any tickets for speeding yet...
    I should get that corrected, how does a guy get a speedo corrected?
    Oh yea, 3.9 EFI V6 Dodge with an OD 5 speed and 3:55 rear gears. I thought I was getting 17-18 around town... Gene
  16. Kan Kustom
    Kan Kustom
    Note to self. Get fountain of youth, then money tree.....
    Tomincanada likes this.
  17. squirrel
    usually you change the driven gear in the transmission.
  18. gene-koning
    gene-koning
    This 5 speed has both a speedo cable and an electronic sensor, (the next year they did away with the cable), does it still have a changeable gear?
  19. squirrel
    If it has a cable, then it has a gear. I don't know what they look like inside, but I bet you could take it apart and find out!
    hipster likes this.
  20. gimpyshotrods
    gimpyshotrods
    I think that one actually does. If memory serves me, until the end of the production run, you can pull out the electronic drive, which has a drive/driven ge****t, and put in a cable one, or, in your case, just put in a different driven gear.
    I think these cross reference with Jeep speedometer gears.
  21. gimpyshotrods
    gimpyshotrods
    My time machine will be finished a few years ago.
    Kan Kustom and Ned Ludd like this.
  22. jazz1
    jazz1
    15.681 US mpg on the highway,,i should make a point of improving on this immediately
  23. dave 62 pb
    dave 62 pb
    Very pleased with my 59 Edsel 223 - 2 speed auto 18-20 mpg local driving 10 mile radius and 24-25 on motorway at 70 mph (UK gall = 4.55 liters to gallon )
  24. Truck64
    Truck64
    from Ioway
    I thought you guyf across the pond used hogsheadf to the furlong.
    Jet96, hipster and Tman like this.
  25. e1956v
    e1956v
    Alliance Vendor
    Dodge speedometer driven gears are about 3% per tooth so you would need to replace it with a driven gear with 8 teeth less than the one you have now. That should correct most of the error. Don't forget to line up the speedometer sleeve with the amount of teeth of the driven gear, you might have to rotate the sleeve.
  26. dave 62 pb
    dave 62 pb
    Truck64 that was the old system, the new one is called ROG rip off government , basically works out as
    1 USD per gallon = 3 UKP per gallon LOL
    Truck64 likes this.
  27. CoolYourJets
    CoolYourJets
    Oh, man. That milage ****s => How many pounds are you hauling at that point? I had no idea trucks got that low of mileage. I thought the diesel would help you.
  28. Racer29
    Racer29
    The average gross weight with this particular load is usually between 75000 and 80000 pounds. The load itself is around 45000-50000 on average. Big diesels make a ALOT of power and the cost of power is fuel. This engine makes 500hp and 1850lb ft if torque. If you're getting 6-7 mpg in a rig pulling a load you are doing good. Some may do slightly better with a tune.
    Tman likes this.
  29. bobss396
    bobss396
    I would have to drive the Ford like a normal person to see any big difference. So far I've tracked my MPG twice and got 10 and 9.4.
  30. Racer29
    Racer29
