Technical fuel press problem, step by step
Discussion in 'The Hokey Ass Message Board' started by flynstone, Dec 3, 2018.
  1. flynstone
    flynstone
    ok , so my car was starving for gas or flooding lol... check flow at carb by pulling hose off, appears to be weak so I put on a regulator and gauge. yup, weak 1 lbs sometimes. ok I've had a bad hose at tank which ****s air, so I plugged the end at tank and blew into hose up front.. no flow hmmmm… drop the tank, pull the sender unit and guess what? small hole at weld on sender (see pic)....ran good with a full tank ...lol dammm
    AVater likes this.
  2. AVater
    AVater
    Great detective work there!
  3. little red 50
    little red 50
    Glad you found it, that one could have drove you crazy.
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I had almost the same, and yes it drove me nuts. The fuel line at it's highest point over the rear end had a crack in it by the time I found it. At that point the car stopped all together and refused to run where as when it started it would just stumble going up a grade under a medium load then got worse to where if I stood on it on level surface the car would nose over. I know this is a long story but I wrote it in hopes that someone may read this that and are having the same issue better understand to not start buying parts that won't fix a thing. Yes, I was younger then but the session guys I would talk to about it never led me in the right direction either. Moral-"Live and Learn"
