fuel pressure gauge question
Discussion in 'The Hokey Ass Message Board' started by longhorizon, May 11, 2013.
  1. longhorizon
    longhorizon
    I'd like to install a fuel pressure gauge inside the engine compartment. It appears the liquid filled ones (though recommended over non-liquid filled) are rated only to about 140 degrees Fahrenheit. For reasons I won't go into, my engine compartment probably gets hotter than that. I'm concerned about reliability (yet another source of a potential leak, and then potential disaster...)
    Would appreciate suggestions for brand /model within reasonable cost parameters.
    Thanks much.
    longhorizon
  2. M224SPEED
    M224SPEED
    from Missouri
    I would not for any reason put a fuel pressure gauge on the inside of a ride !!!
  3. oj
    oj
    I like the 1 1/2" Marshall and have used tons of them. I wouldn't get liquid filled, pressure gets inside the case and they won't read right, the liquid filled is handy for a boat etc where bouncing could affect the gage reading but in a hot rod and esp under the hood the only time you can read it is when you are just sitting there, not moving.
  4. Okatoma cruiser
    Okatoma cruiser
    from Ms
    Electric fuel pressure gauge would be safe , the others might burn down car , house , garage, etc
  5. chaddilac
    chaddilac
    Just curious.... how would you read it driving down the road if it's in the engine compartment?
  6. You just need to read it while in the driveway, tuning and initial setup, ie: tri-power.
    Holley makes a nice one.
  7. Stu D Baker
    Stu D Baker
    from Illinois
    I don't believe he's wanting to put the pressure gauge "inside" the car. OP said engine compartment. Stu
  8. 19Fordy
    19Fordy
    Could you install a fuel pressure regulator with a gauge? Keep it away from the exhaust manifold.
  9. Mount it on the back of your blower !!
  10. 61 Fairlane
    61 Fairlane
    Thats what they make isolators for, so you can have one in the car and not have to worry about fuel getting into the p***enger compartment.
  11. Mike51Merc
    Mike51Merc
    The liquid in the gauges expands with heat. The expansion causes the needle to drop--- giving a false reading of "0" fuel pressure. This drove me (and a friend) crazy until I discovered that by "burping" the rubber plug on the gauge the reading will return to normal.
    Other than that problem, I don't think the heat will cause anything dangerous to happen.
  12. chaos10meter
    chaos10meter
    from PA.
    I have used them on the engine for years without problems , several different cars ?
  13. Most of the time I need to see the fuel pressure while driving and under load.
    I usually stick it under the wiper so I can see it on a test drive for drivability issues. But that's just temporary
  14. bgaro
    bgaro
    i've been thinking of the same thing. i gotta keep an eye on fuel pressure for tri-power.i was just gonna run a regulator. now, maybe gauge too? what brands work best, the price range is all over the place.
  15. TR Waters
    TR Waters
    from Vermont
    Exactly.
  16. Gene Boul
    Gene Boul
    Fuel pressure gauge inside ****pit seems to work fine. My guess is almost every nitro car on the planet uses one...I certainally did. We used a liquid filled gauge and a check valve with a way to "burp" the gauge. At the end of a run we would download the info and actually track fuel pressure vs RPM / time.
  17. longhorizon
    longhorizon
    Thanks guys. Will mull this over a bit more...
    longhorizon
