Technical Fuel Pressure Gauges?
Discussion in 'Traditional Hot Rods' started by Tumblin' Dice, Feb 18, 2026.
  1. alchemy
    alchemy
    Bummer, I was looking for a small one to mount to the fuel block.
    dana barlow likes this.
  2. Kid Rocker
    Kid Rocker
    mad mikey likes this.
  3. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Here was my old setup, @Tumblin' Dice. It was a vintage SW 10psi gauge that I mounted directly off the line and clamped to the firewall. Worked great for the whole time I drove the car.
  4. BJR
    BJR
    Does anyone make an electric fuel pressure gauge, so you don''t have a fuel line in the cabin?
  5. 19Eddy30
    19Eddy30
    from VA
    Yes there are Electric gauges
    Requires a sensor @ fuel supply with usually 2 wire plug to gauge
    Then positive & a ground
    Autometer & maybe other make a
    Diaphragm unit , gas to diaphragm
    Then from out port of diaphram
    Uses no flammable liquid to Mech gauge
    TrailerTrashToo and RodStRace like this.
  6. CSPIDY
    CSPIDY
    Gauges are most accurate in the center of the scale
    Ideally if you’re running at 2.5-3 psi a 5 psi gauge would be best.
    10 not so bad, hard to find
    I settled on a 15 because of availability
  7. wuga
    wuga
    On my banger running twin 97s, I run a Holly Mighty Mite 12-425 putting out 1.5-2.5 psi and a full sweep 10 psi gauge. I had not come across a 5 psi gauge before but there are several shown on Amazon. At the low psi requirements of the 97, you need a gauge easily read. I have to agree with CSPIDY on this one.
    Warren
  8. TrailerTrashToo
    TrailerTrashToo
    I have used several Stewart Warner electric fuel pressure gauges over the last 20+ years. Here in Southern Arizona, I used them in off-topic vehicles to keep track of impending vapor lock and electric fuel pump failures. In specific, 1962 Volvo sedan, 1971 IH pickup and a 1974 IH Scout. No failures. The most recent was the 1962 Volvo - A victim of an inattentive driver (rear ended...).
    Pressure gauge:
    https://www.summitracing.com/parts/sww-82333 - $76.99 - In stock
    Requires the following sender:
    https://www.summitracing.com/parts/sww-82504-f - $72.99 - In stock
    The present off-topic vehicle (1986 Ford F150 with a ***mins 4bt diesel engine). Tried a couple of digital gauges - at the time, the Stewart Warner 8254-F sender was back ordered every where, with no predicted delivery times.
    The 0-100 PSI electric gauge setup was a disaster. It did not read fuel pressures below 10 PSI.
    My current electronic servo gauge unit is too "Las Vegas" looking for an on-topic ride. Serves my need to keep track of the low pressure (4 to 7 PSI) electric boost pumps. A backup pump comes in line with the flip of a toggle switch.
    Russ
  9. 19Eddy30
    19Eddy30
    from VA
    If you go Electric you want to use a sensor close to your working Psi
    If I want a 2 Psi accurate reading I would not use
    100 Psi sensor ,I would use 10 Psi sensor , Me when needing a accurate reading , I verified with other gauges. sensors yes you end up with 3 & 4 of the same items , Sensor grade qualities matter , Good Quality and name brands will have a spec , data sheet for working
    Minimum and max.
    I have talked to Marsh , Autometer & other about small silver dollar size mechanical gauges
    Why they do not make in low pressure I was told to be accurate the parts would be to big for that style gauge for
    max 5 psi.
    All gauges are not made equal
    There different between a $30 & a $150 plus , Aerospace ,Aviation ,Commercial
    RodStRace likes this.
  10. Bandit Billy
    Bandit Billy
    Tumblin' Dice, CSPIDY and Hotrodmyk like this.
  11. alchemy
    alchemy
    I ask anyone to show me any 0-5 or even 0-10 psi gauge in a small size to mount right on the fuel block. Non existent as far as I’ve searched.
    CSPIDY likes this.
  12. tarheelrodr
    tarheelrodr
    hotrodmyk, I have that same gauge but it has failed with less than 1000 miles. I had it direct mounted on rear carb banjo bolt. Is yours a liquid filled ? How or where do you have it mounted?
  13. Hotrodmyk
    Hotrodmyk
    @tarheelrodr Mine is a dry gauge, been on 10 plus years. I had a liquid filled one that did not like the hot engine compartment. It is in the fuel line before the carb.
    MMM1693 and tarheelrodr like this.
  14. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Not sure if this is what you're talking about, but here's another angle. I bought the gauge off a HAMBer who ran it on his dragster. No issues at all in 3.5 years of usage.
  15. 19Eddy30
    19Eddy30
    from VA
    @J.Ukrop
    Looks like a 2 & 16th ?
    The one's others are asking about
    Like 1-1/4 .
  16. winduptoy
    winduptoy
    Lanair makes waste oil fired, unit heaters...probably a burner oil pressure gauge
    I use a Winters Instrument manufactured 1.5" 0-15 psi gauge....because that is what the instrument supply house had that I bought pneumatic building controls from....
    Pneumatic controls use 0-30 psi on a main and 0-15 psi on branch lines so lots of small panel gauges were used
    a quick search on https://www.ebay.com/itm/1265143087...bbOXooVRIzgQQZ8S8oVTd3Lw==|tkp:Bk9SR6zV6MSWZw
  17. Eric David Bru
    Eric David Bru
    from Iowa
  18. 3blapcam
    3blapcam
    I have one. I'll take a picture later. Unfortunately, I cannot find them anymore... and could really use a small stockpile.
    3blap.
  19. alchemy
    alchemy
    ****ster used to sell them, but they aren’t available anymore. He had them custom made. I don’t think there are any low range gauges on the market now.
  20. 3blapcam
    3blapcam
    @alchemy... that's what I have. Wish I had more. I'll still take a picture... because why not?! Maybe it'll motivate someone to carry that torch?!
    3blap.
  21. Tumblin' Dice
    Tumblin' Dice
    from Las Vegas
    I appreciate the offer!
    I got the 0-15psi Marshall installed today, and while it looks great (although I'm not sure about the placement of it here...), looks like it may not be registering the low PSI of the gravity-fed cowl tank. Let me play around with it a bit more, but perhaps dropping down to a 0-10psi may give it a better readout.
    But, to anyone else wondering, the quality of the Marshall is really nice and as of right now I would recommend them. It's also small enough to run off a fuel block for sure.
    Hotrodmyk likes this.
  22. swifty
    swifty
    @Tumblin Dice I didn't realise that you were using the stock A fuel tank. Your gauge will only be measuring the static head from the fuel level in the tank to the gauge. Going back over 20 years to my pump industry days I remember that 2.31 feet head of water equals 1.0psi. Now I don't think that your fuel level would be close to 2.31 feet above your gauge therefore the pressure at your gauge will be less than 1.0 psi and the gauge does not really read below that figure. Also gasoline has an SG of about 0.8 so that makes your situation even worse.
  23. ydopen
    ydopen
    Here is one that screws in. I will have to look for the name. 10 psi.
    Hotrodmyk and alchemy like this.
  24. Fordors
    Fordors
    I not positive but that looks like a Holley 0-15 psi gauge to me. I don’t think Holley ever marketed a 10 psi gauge.
    swifty and RodStRace like this.
  25. RodStRace
    RodStRace
    dmar836, ClayMart and 19Eddy30 like this.
  26. Tumblin' Dice
    Tumblin' Dice
    from Las Vegas
    See, I gotta take off my pants to count to 21, so this is the information that I come here for. That's really helpful, thanks!
    I wanted a gauge on there just to give me a data point that I'm not exceeding 3-4psi on a full tank of gas, and also because I can't/won't do the kind of math you mentioned...
    dmar836 likes this.
  27. 3blapcam
    3blapcam
    ****'s Hot Rod Shop gauge...
    Hotrodmyk, swifty and alchemy like this.
  28. dmar836
    dmar836
    Dumb observation but it looks like the ****'s gauge is just a different face "resolution" but with the same functional range as a 0-15 gauge.
  29. 3blapcam
    3blapcam
    It has to be calibrated differently because you can dial in 1.75psi without issue.
    3blap.
  30. 19Fordy
    19Fordy
    Ok, I bet China will be selling low pressure gauges pretty soon.
    3blapcam likes this.
