my friend is running a 383 sbc with holley 4 barrel ,everything new.what should the fuel pressure at the carb be.its running an electric fuel pump thanx
I am running the same setup with an Edelbrock 600,Carter elec. fuel pump,with a 350 auto @5&1/2lbs . of pressure with no problems. Don't forget fuel filter between tank and pump. Check to see how much pressure the pump puts out you may have to use a regulator......................
truck was built in the states and shipped to us.gauge at carb reads 8.5 psi.it will tick over at 900-1000 rpm but dies or soundsbad below this.my diagnosis is the carb is flooding a little due to high fuel pressure .your opinions appreciated
