Technical Fuel Pressure regulator
Discussion in 'The Hokey Ass Message Board' started by B.A.KING, Dec 11, 2018.
  1. Beanscoot
    Beanscoot
    The pressure range is 1-1/2 psi to 5 psi according to one of the ebay sellers.
    The pressure is adjusted by unscrewing the central acorn nut which exposes a slotted screw, which is screwed in or out to change the pressure.
    big duece likes this.
  2. jimmy six
    jimmy six
    Nice can it be bought with threaded fittings?
  3. Beanscoot
    Beanscoot
    The ones I've seen, and the ones pictured on ebay all have the press-in or molded in fittings, 5/16" size (or more likely 8mm since it's a European part).
  4. Jmountainjr
    Jmountainjr
    The V8 model comes in several end configurations including 1/8 NPT.
    egads likes this.
  5. jimmy six
    jimmy six
    I was thinking the pressed in br*** fittings could be removed and pipe threads added so standard flare steel fitting could be installed but I didn't want to spend the $$ to experiment..
  6. B.A.KING
    B.A.KING
    Thats very good information .Thanks
  7. Beanscoot
    Beanscoot
    Mine with the pressed in tube fittings does not have enough material to drill and tap for 1/8 NPT.
  8. Jmountainjr
    Jmountainjr
