Fuel Pump Repair Kit?
Discussion in 'The Hokey Ass Message Board' started by Kerry, Aug 2, 2005.
  1. Kerry
    Kerry
    I'm running an old Holley racing fuel pump but it's getting a bit ******* on the road. Thought I'd put a rebuild kit in it. Holley used to list 12-858 as the number for a repair kit for a lower pressure pump that I think would work better for me than the high pressure one Edelbrodk lists. Problem is nobody seems to have it anymore.
    Any ideas where I could find it or would I be better off to just get the high pressure, high $$$ kit?
  2. AHotRod
    AHotRod
  3. Winfab
    Winfab
    I sent a PM your way.
    For street use I'd stay with lower pressure (6-8 PSI) unless you're feeding a big engine and also have a pressure regulator.
  4. Kerry
    Kerry
    The carter is tempting. I understand that Hot Heads has an adapter to use Mopar pumps. Problem is I'm lazy and would like to use the same pump so I don't have to re-engineer my pressure regulators and lines. Using a big pump for the volume with Strombergs means getting the pressure down. Looks like Winfab might be able to hook me up with just what I'm looking for. Too Cool!
  5. Yo Baby
    Yo Baby
    Get the repair kit and just reuse the old spring on the byp*** and the pressure remains the same.
    T.OUT
