Technical Fuel Pumps
Discussion in 'Traditional Hot Rods' started by johncard, Dec 5, 2017.
  1. johncard
    johncard
    How about this for a vapor lock fix in early V-8: Use the highest pressure furl pump spring available to keep the pressure in the pump above the fuel vapor pressure, then use a regulator between the fuel pump and the carburetor(s) to keep from overpowering the needle valve(s)
