Technical Fuel sender unit. ... how do I set it up??
Discussion in 'The Hokey Ass Message Board' started by miki562, Apr 12, 2017.
  1. miki562
    miki562
    Hey guys, so I bought a sending unit compatible with the socal speed shop gauges I got, and a friend of mine is going to hook them up for me, but the problem I'm facing is how do I set it up inside my tank? This is my first project and I'm super lost, I want to save my friend the trouble of setting it up since he is taking care of running all the electrical for me, help![​IMG]
    Sent from my SAMSUNG-SM-G925A using The H.A.M.B. mobile app
  2. squirrel
    put the pivot about half way up the tank, and make the arm long enough that the float will just touch the bottom of the tank at the lower end of travel, and just touch the top at the upper end of travel.
  3. typo41
    typo41
    Stick on float
    Stick in empty (you did empty it?)tank
    If the float hits either shorten it or bend it
    Check for full float position to make sure it shows full, but hold full until it drops to half full
    You can check with a jumper against the tank.
  4. pprather
    pprather
  5. miki562
    miki562
