1952-59 Ford Fuel Sending Unit
Discussion in 'Off Topic Hot Rods & Customs' started by firerod63, Aug 5, 2011.
  1. firerod63
    firerod63
    Hey guys. Anyone with a 52-54 replaced their fuel level sending unit in the tank lately? My gauge reads either full or empty, no in between. The nice part is, when it reads empty all I have to do is go around the corner and I have a full tank of gas again. Yay! So much cheaper than going to the gas station and spending $3.50 a gallon. Anyway, I was curious if any of em were better than the others, which ones to avoid, tips & tricks, etc. I'm still running the 6V system, so any help would be great! Thanks in advance guys!
  2. 1 Ford fan
    1 Ford fan
    Be sure to check the float, they have been known to rot away, and is the car converted to 12 volt? If it's still 6 volt most of the retailers (Concourse,Macs) cary them. Gerry
  3. i'm in the same boat as you buddy...i just pulled the aftermarket sender and gauge out of my car and i'm thinking of going back to stock..i'm just not sure if my stock gauge is any good..and i need a sender..Mac's has em pretty cheap..so does ebay.
  4. firerod63
    firerod63
    Thanks guys. Unfortunately, or fortunately, depending on how you look at it, the car is still 6V. Guess I will look around and see what I can find. Just didn't know if anyone had better luck with one brand/supplier vs another...
