Hot Rods Fuel shut off valve
Discussion in 'The Hokey Ass Message Board' started by walter, Jan 3, 2016.
Tags:
  1. walter
    walter
    Is any one using a shut off valve to isolate the fuel tank. If so what type of valve are you using?
    Thanks in advance!
    Walter
  2. Hackerbilt
    Hackerbilt
    My T has a fuel rated ball valve up near the engine.
    Ball valves are nice because its only a 1/4 turn with the lever rather than having to unscrew a knob or something.
    Just make sure its fuel rated rather than a water valve as not all of those have plastic inside that can actually handle petroleum.
  3. old1946truck
    old1946truck
    Would there be any way to attach a cable to one so it can be opened and closed from inside the vehicle?
  4. walter
    walter
    the reason I asked was I installed a br*** fuel rated valve just off the tank to isolate during storage. Was great for about a 2 months and went out to the shop and gas was dripping from the valve. Just spent an hour draining the tank and removeing the valve. Thinking about deleting in completely. I never put one in a car before so maybe I am over engineering.
    Walter
  5. Go over to fordbarn and ask what the guys are using to turn off their fuel tanks in place of the original valve. Unless the original parts are properly rebuilt the gas valve under the tank and the needle valve in the carburetor leak creating a bad smell if not a fire hazard. There is some sort of electric shut off valve that many people use since they don't want to spend the time to fix things properly.
    Charlie Stephens
  6. 19Eddy30
    19Eddy30
    from VA
    A mechanical fuel injection fuel shut off valve can be used ,
  7. stimpy
    stimpy
    I have used a dual tank valve from a O/T 78 chevy k-20 Pickup , its electric and you can wire it to a intertia switch for accident protection too . you power one side and it opens and leave the other side capped plus it has return line capability too . also some peterbilts use a fuel tank selector valve that is one line but they are $95
  8. gnichols
    gnichols
    from Tampa, FL
    ^ Good idea! RE the valve, many old Fords had them but the line size might not be large enough if you have a high performance engine or EFI with greater flow requirements. I suspect larger valves are available, hit the web. Gary
  9. Don's Hot Rods
    Don's Hot Rods
    from florida
  10. V8 Bob
    V8 Bob
  11. 4wd1936
    4wd1936
    from NY
    V8 Bob's suggestion is a good one. I use a race car ball valve like the Earls' shown, usually from Speedway, as they are intended to shut off all kinds of nasty fuel and are stainless with nylon seal. Some like Earls can have a cable attached for access from inside but it will require a heavy duty cable. Great also for shutting off the fuel in front of a cartridge fuel filter for replacement.
  12. Hackerbilt
    Hackerbilt
    The fuel rated ball valve on mine has been in use for at least 10 years. Not a single drip.
    I guess they don't make them like they used too...or perhaps someone switched a water valve with a fuel valve to save a couple of bucks...and you ended up with the water valve!
    Don and V8Bob make some good suggestions...
  13. Mike51Merc
    Mike51Merc
    I'd say they're only needed in a gravity flow situation which most cars don't have. I added one to my lawn tractor because one spring I found the entire fuel tank had emptied into the combustion chamber and the crankcase.
  14. Hackerbilt
    Hackerbilt
    As part of my redoing of my T, I lowered the tank 3" so I'm in a slightly better situation...but the ball valve had been installed by the previous owner when a needle stuck in the Holley carb and the tank drained, filling the engine with fuel.
    Luckly it was noticed before the engine was cranked.
    The engine had to have the plugs pulled so the fuel could drain and the oil had to be changed. Trying to start it would have hydro-locked the engine and most likely ruined it.
    It's a good idea (and a small price for the insurance it provides) on any car that potentially could siphon fuel by gravity...even with a rear tank.
  15. Bert Kollar
    Bert Kollar
    I used a Swagelok stainless steel , found a deal on ebay. They make the finest around. Used in nuclear everything. It will outlast me.
