Fuel smell
Discussion in 'The Hokey Ass Message Board' started by steves29, Jul 28, 2013.
  1. steves29
    steves29
    Hi fellas. I have 3 94s on edelbrock manifold on flathead. Center primary and other 2 secondarys. I am trying to minimize gas smell while cruising on the primary. I connected the filter bases together at the nock-outs. Do you think a larger common air filter will help?
  2. hawkerdriver
    hawkerdriver
    The gas smell is what it's all about man!
    How much fuel pressure are you running? Holleys don't need much. Might be your problem.
    (There...fixed it)
  3. gimpyshotrods
    gimpyshotrods
    Yup, except that 94's are Holleys, not Strombergs. Even so, a regulator is not a bad idea.
  4. HOTRODPRIMER
    HOTRODPRIMER
    Fuel regulator will help,,2.5 lbs is about the max. HRP
  5. steves29
    steves29
    Regulator at 2.5. Maybe I will try 2 psi.
