fuel starvation question
Discussion in 'The Hokey Ass Message Board' started by 57ford/60thunderbird, Jul 3, 2012.
  1. robber
    robber
    Maybe look to see if you have a problem with the float sticking.
  2. Ole don
    Ole don
    Any AFB or Edelbrock carb should have an insulating spacer between the carb and the manifold. They are very heat sensitive. Right now I have one that is only 3/8 thick and it changes everything. Then, check the needle and seat, if there is a bronze filter by the needle and seat, and the float level.
  3. mr.32
    mr.32
    That carb spacer has helped me on several cars. Just because its new, doesn't mean it's good. Pep boys sells a fuel pressure gauge ( in line at carb ) that would help.
  4. shotrod
    shotrod
    fuel float set to low in the carb?
  5. ok i think i MIGHT have got it fixed still havent driven it i will tomorrow i THINK the problem was appearently the wire going to the positive side of the coil is/was a resistor wire and it went bad i installed a chrysler old style 2 post ballast resistor today and it seems alot better ill find out
    it probably had more issues then just the fried wire but i fixed them while arriving at the wire thing
  6. well i drove it farther today then i had been able to for the last 5 weeks ....do i say its fixed now? im going to drive it to work in the morning , hopefully ill get back home under its own power
  7. budd
    budd
    did you make it home from work yet?
  8. worken2much
    worken2much
    I agree with Mustang 6147...coils shouldn't be hot. It used to be on the intake. When you installed the new intake, any chance the wires on the coil got switched around? Now out on the fender, it should be ambient temperature. Negative side of the coil always goes to the distributor. Worth a look.
    Worken2much
  9. lol yeah 8 hours ago i even ran a few errands on the way home in it no problems a couple of weeks ago i couldnt have done that
  10. blitz
    blitz
    good man, dosent it feel great. now you have a good running truck and all it took was alil playing and maybe a couple of bucks. give yer self a patt an the back and go drive your truck somemore.
