Fuel system question
Discussion in 'The Hokey Ass Message Board' started by upspirate, Sep 28, 2012.
  1. upspirate
    upspirate
    I'm changing my fuel system back to a mechanical pump from electric.
    Mild 327 SBC, Edelbrock 600 CFM no special fuel flow requirements, no racing etc
    I bought this pump
    https://www.gearheadworld.com/store/Small-Block-Chevy-Chrome-Mechanical-Fuel-Pump-P4954.aspx
    and this filter
    http://www.parrautomotive.com/index...egory_id=441/home_id=-1/mode=prod/prd3709.htm
    Question is: I don't really have room up front between the pump and carb to mount this filter so the pump pushes through as in a stock set-up.
    Any reason I shouldn't mount filter back near the tank, and pull through the filter to the pump?? (there is room to mount below the bottom of the tank to a sturdy support)
  2. jcapps
    jcapps
    from SoCal
    Best to mount that filter on the frame. It really makes no difference, just a cleaner look, but that filter is designed to be mounted under the car
  3. icsamerica
    icsamerica
    Not a good idea to mount a filter before a pump. In general pumps dont like any sort of restriction on the inlet side. It's ok to put a screen before the pump but that's it. Pumps work better when the push through the filter. Even a slightly clogged filter will starve a pump if its on the inlet side.
  4. Jokester
    Jokester
    I've mounted them back there on a couple of cars....but I don't anymore. I've twice had to change them on the side of the road, and it's no picnic. The fuel runs down your arms and into your face, and no place handy to wash up afterwards.
    Now I mount them where I can see them and reach them from a standing position, no matter what it takes to build a bracket for it.
    my 2¢
    .bjb
  5. Engine man
    Engine man
    from Wisconsin
    Mechanical pumps are great ****ers so the filter between the tank and pump will work fine but, as has been pointed out, it isn't easy to change them, unless you put a shutoff valve in.
  6. 26 T Ford RPU
    26 T Ford RPU
    I would rather have **** from the tank caught before the pump as to not let the pump valves get blocked or stuck. You can also extend the line from pump to carb and body mount one in the engine bay.JW
  7. upspirate
    upspirate
    I thought about mounting on the firewall,I have room next to or below a fuel block.
    A shut off valve would be a great idea if mounting in the rear as it would be below the tank bottom.....HHHMMMM
    Thanks for all the input
