Hot Rods Fuel tank inside car...
Discussion in 'The Hokey Ass Message Board' started by Topolino Kid, Jun 14, 2026.
  1. Need to know if this is a major issue if I go to the drag strip... I've read about tanks in the trunk... But can't find any info on inside the car...my 1938 Bantam doesn't have a trunk...I figured there's a box to build or something to make it safe.... Thanks...n hopefully it's feasible..
  2. 66GMC GUY
    66GMC GUY
    Its been a while since I've read up on the rules, but why not do a Moon style front tank? Just an idea.
    captaintaytay and chryslerfan55 like this.
  3. I've read read about those... But I plan on street driving it also.... Besides I like the cleaner profile
    66GMC GUY likes this.
  4. I like the profile as is
  5. swade41
    swade41
    from Buffalo,NY
    Yes you need a bulkhead between p***enger compartment and fuel tank. You'll also need a sealed battery box if that in the p***enger compartment.
    I recently built one for my Henry J because it doesn't have a trunk and I moved the fuel cell inside.
  6. jimmy six
    jimmy six
    What was its stock location?
  7. Hotwyr
    Hotwyr
    What shade 41 said. Plus it needs to be vented to the outside.
    Just Gary likes this.
  8. So just use the proper thickness steel or aluminum n attach it to the cars walls..
  9. Outside in the rear is where there factory tank was... It's the flashed over area below the black factor paint
  10. swade41
    swade41
    from Buffalo,NY
    0.024" steel or 0.032" aluminum
    You have to think about how you're going to fill it too
  11. Are you saying that you have to have a sealed system....n then having to unscrew a panel or something to get to the tank??
  12. tomcat11
    tomcat11
    The rear bulkhead should be sealed. If not the tech inspectors may not p*** it. Remember the purpose is to keep fuel and fire out of the drivers compartment in a wreck or roll over. With your Bantam it looks like you need a filler neck to the outside. As mentioned vent to the out side. Roll over valves are good to have too. What are you using as a tank?
    alanp561 and swade41 like this.
  13. The tank is in a picture above
    tomcat11 likes this.
  14. swade41
    swade41
    from Buffalo,NY
  15. jnaki
    jnaki
    Hello,
    Ever since the popularity of the moon tanks inside of the cab area with seats in hot rods and drag race cars, it was an accident waiting to happen. Sitting in the p***enger seat of our 1940 willys coupe with a Moon tank in front of me was cool, but thinking about it later, stupid. Flammable gas just inches away from anyone inside on the bucket seats… what were we thinking?
    Well, for one, we used the stock gas tank full of water for extra real wheel weight. So, we needed a new tank anyway. Most of the top race cars in our gas coupe cl***es were using moon tanks, inside. It had a pump attached and it needed to have it close to the driver to put in more pressure for the quarter mile run.
    1958-59 Gene Adams Oldsmobile Sedan Gas Coupe record holder. Moon Gas Tank inside the cab.
    As much as the good looks of the Moon Tank and Pressure Pump inside of the cab area, all racers were told to move them out of the cab in September 1960, due to fire hazards and explosions.
    Drag News August-September 1960
    1959-60 photo of a modified Corvette interior.
    This ruling was due to our 671 SBC motor and clutch exploding with a resulting fire inside of the bucket seat area where the moon tank exploded. The aftermath was the ruling of removing the gas tanks from inside and placing them in the trunk or in front of the motor.
    Jnaki
    This is what the rules committee of all racing organizations wanted… in front, but inside of the grille and bumper. Below:
    upload_2026-6-15_4-45-5.png thanks, @elgringo71
    The good thing was, better safety and no more interior fires. The bad thing was some folks decided to place them in front of the grille, which removes the actual safety factor of daily driver Gas Coupes and Sedans in real traffic. Who wants to have a collision with an aluminum gas tank as a bumper? Insurance companies never inspected the real Gas Coupes and Sedans. The drag strips ok’d the set up as they ***umed the cars were compe***ion only. Ha… some ***umption…
    So, do not put the tank anywhere inside of the cab, even as small as it is. Most drag racing organizations have similar rules and would require you to put it elsewhere, like in the back, outside. In the 60s, after the ruling, even those with small cab interiors put them in the back, outside. Or if you have a legal trunk, which you don’t. YRMV
    Onemansjunk and alanp561 like this.
  16. redo32
    redo32
    Looks like the stock tank was mounted in back like a '32 Ford. With a little thought and design you should be able to make something that doesn't look too bad. With the outside headers, do you have room to make a pair of saddle tanks inside the frame?
  17. I was looking at mine today...I have enough room to enclose it and still keep the factory smugglers box.... And I've a couple of Vega fuel filler tubes, but one that looks like the angle is just about perfect alignment right into my tank..
    I still have a long list of STILL NEEDS..... But moving in a good direction the last four weeks... Thanks for sharing the tank info!!
    panhead_pete and swade41 like this.
  18. 19Eddy30
    19Eddy30
    from VA
    Dont get it
    Model Ts
    Model A 's
    Pick ups up until 70's
    Lawn mower tractor
    Tractors
    Sitting on the rear
    Leg's straddling driveshaft ,transmission
    Or just putting gas in a steal tank .
    Nomex up , fire bottle .
    Main thing good fittings
    If using hose , GOOD hose
    Make sure to vent good out side of
    P***enger compartment.
    Tanks on Rear no better
    Vega , Pinto
    My self have had all listed above
    Still have some
  19. No.. Only a couple inches there
