Technical fuel/vacuum pump
Discussion in 'The Hokey Ass Message Board' started by DeltaBravo(DB), Dec 7, 2020.
  1. When I got this car the original fuel pump was byp***ed and all connections were removed so I have no reference. The engine was running with an electric fuel pump. Could put it back that way but prefer not too. Got my rebuilt replacement fuel pump today. I know it is a combination vacuum, fuel pump and filter.
    Once again asking you folks with more experience what goes where. I've hopefully correctly uploaded an image from the manual and labled the connections with letters. Can anyone connect the dots for me? where does "A" come from or go and so on etc. img001.jpg img001.jpg
  2. studebakerjoe
    studebakerjoe
    D and E are the vacuum side of things. The fuel pump is the bottom.
    DeltaBravo(DB) likes this.
  3. One goes to the wiper motor. Any idea of the other?
  4. studebakerjoe
    studebakerjoe
    As far as the fuel pump side if you remove the bowl on the bottom you should see one port open directly into the bowl that would be the line bringing the fuel to the pump. It fills the bowl first then gets pumped out of the bowl.
  5. Guessing A is the fuel in and B is fuel out and C is a drain plug?
  6. studebakerjoe
    studebakerjoe
    The other side of the vacuum section goes to the intake manifold. When there isnt enough vacuum from the engine for the wipers the pump creates vacuum.
    DeltaBravo(DB) and jaracer like this.
  7. Thanks Joe
  8. studebakerjoe do you happen to where on the intake manifold the vacuum line is supposed to go? I only have one hole that I can see that has a plug in it
