Technical Full Floating Rod Bearings
Discussion in 'The Hokey Ass Message Board' started by Ldjr003, May 8, 2020.
  1. King ford
    King ford
    from 08302
    Weelllll, I'm not going to insult anybody hopefully and won't get my tighty whiteys in a knot but didn't the full floating rod " bearings" to most of us start with the 24 stud engines?...I have a 1940 or so vintage BAA I believe is its designation with full floaters on the rod journals of the crank.....
  2. Ldjr003
    Ldjr003
    Will get back to you on that. Thank you !!!!!!!
  3. alchemy
    alchemy
    The full floaters began with the first loose insert bearings on a flathead, in later 36. Known as LB blocks. They were 21 stud.
  4. Budget36
    Budget36
    Tell ya wife it's not really 10 inches...admit it...man up!
  5. 1934coupe
    1934coupe
    Such drama, I read all the posts and am totally confused so I have to stop. Hope you find an answer to your question.
    Pat
  6. seb fontana
    seb fontana
    from ct
    He was thinking MM
    Budget36 likes this.
  7. Budget36
    Budget36
    Ray get's a little full of himself, up to us to bring him back to earth;)
  8. dreracecar
    dreracecar
    from so-cal
    Did not know that, How come that didnt catch on with the later engines?
    1934coupe likes this.
  9. Hnstray
    Hnstray
    from Quincy, IL
    Perhaps, but I am obviously in good company on that score....:D
    Ray
    metlmunchr and Budget36 like this.
  10. Budget36
    Budget36
    Ray, I like it that knowlegable folks like yourself can take a ribbing.
    + 2.1 in my book (scale goes to 2.2)
  11. dreracecar
    dreracecar
    from so-cal
    Question??? how does the bearing get oil fed to both sides? With the crank providing oil to the ID/journal and escaping from bearing tolerences and side clearence, would the be pressure drop be too much to support the OD of the bearing oiling?
  12. arkiehotrods
    arkiehotrods
    This might be some helpful reading
    https://www.jalopyjournal.com/forum/threads/flathead-main-bearings.1104631/
    I had a '47 Ford with 59AB engine with full-floating rod bearings. I actually had a couple of bearings de-laminate, causing a rod knock. Drained oil, pieces of bearing came out with the oil. Tore down engine, crank was not hurt at all. New bearings, checked clearances, re***embled, engine ran great.
    Hnstray likes this.
