Full Oil Filter for Flathead
Discussion in 'The Hokey Ass Message Board' started by 38 Ford Guy, Jun 25, 2012.
  1. 38 Ford Guy
    38 Ford Guy
    Hey Guys, I rebuilt my flathead and installed the full oil filter system that Motor City Flatheads designed years back. 1st time I fired it up I had 75 lbs oil pressure and the motor locked up. The machinest opened the tolerance up a bit more and I meticulously put it back together. I got it going again and have just about 500 miles on it and the oil pressure has dropped. I have a low end knock under load which tells me the mains are out. Everything on the block was checked, line hoaned, crank turned, balanced etc. The machinist has been doing motors for over 40 years and has worked on countless flatheads. We are both scratching our heads and now somewhat pointing to the only change, that being the oil pump/filter system. Anyone have any experience with this system good bad or otherwise? Other suggestions?
    Thanks.
  2. kyvetteman
    kyvetteman
    Wow man that ****s. I've been thinking of adding a full filter system to the '49 Merc Flattie in my '32. Now I'm thinking that's not such a good idea. Wish I had some words of wisdom for you. Please let us know what you find out. Good luck.
  3. RMR&C
    RMR&C
    from NW Montana
    Sounds like maybe the mains are not getting full pressure now? Why did it "lock up" the first time?
    I thought about doing that mod on mine, but decided not to.
    The partial flow setup (stock) seems to be working fine for me....Oil stays really clean for about 1500 miles. I change it at 2k miles. Motor is pretty stock though....
    Let us know what you find.
  4. George/Maine
    George/Maine
    I guess they did some drilling near the oil hole back of block.
    I think you may want to remove what ever was done, and block any holes and run with no filter.You only hear of the failures with this setup.
  5. V8 Bob
    V8 Bob
    Not sure why you would fault the MCF system with 75psi. :confused: I've got thousands of miles on my MCF filtration system, along with hundreds of others, with no problems.
    The question was asked, what was the cause of the initial lock up? If bearing related, were new bearings installed? :)
  6. roseville carl
    roseville carl
    Humm bad filter?, something blocking the return from the filter to the block, put a gauge on both sides of the filter and see what you have.........
    I personally like the 95% filtration always worked for me
  7. 38 Ford Guy
    38 Ford Guy
    Both times I installed new Clevlite 77 bearings, crank turned, and on the second time around it did not lock up it has gone 500 miles and is now knocking. I am not blaming the MCF filtration system as I know someone that has it successfully but it is the only change to the motor that both the machinist and myself can suspect. I am looking for feedback good and bad and any advise/experience in this.
  8. customrod48
    customrod48
    I have been running this setup for 8+ years with a slightly modded flatty. Run on the hiway at 2500-2900 RPM no problems. Oil stays clean, pressure stays around 30lbs. 75 pounds sounds high? Sounds like a restriction somewhere.. I remember something about drilling, tapping and plugging the fuel pump rod hole at the rear of the block if you run an electric pump, but thought the result if you didn't do this was no oil pressure...
  9. Da Tinman
    Da Tinman
    you should check the plug in the crossover to make sure that it is not blocking the p***age where the filtered oil goes back into the block.
    If the crossover is blocking that p***age it would show high oil pressure at the sending unit but little or no oil would actually be getting back into the bottom end.
  10. I ran my flathead for several years with not even a byp*** filter on it...I changed the oil when it turned black and I had absolutely no issues whatsoever....I drove about 25,000 miles this way and when I pulled out the flathead, my pal and I put it into his 35 Ford pickup...I ran the flathead in my 52 1/2 ton, which is now powered by a baby Dodge Hemi 1955 vintage....BTW the flattie has twin 97s on an Edelbrock vintage manifold and Sanderson Headers.
  11. railroad
    railroad
    I have a block in the shop for boring right now. I have already modified the block for the filter. I plan on running an electric fuel pump, thus no pump push rod. After much reading I understand if you leave the bushing the oil flow out the bushing hole is neglibile. Without the bushing you need to drive a welch plug into the opening blocking off the oil hole. It sounds like you will at least have to pull the bottom end to address the knock. I would attach a pressurized source of oil to the system to ensure the bottom end is oiling. I will be paying attention to your post.
    good luck,
  12. V8 Bob
    V8 Bob
    The MCF full flow system does not require the crossover plug (or any block machining), only a hole drilled into the oil pan. :)
  13. Da Tinman
    Da Tinman
  14. George/Maine
    George/Maine
    Does your by p*** look like this. veyr poor art work
  15. Andy
    Andy
    It is easy to get the pipe threads too deep and block the p***age when the fitting is screwed in. I would suspect the fitting in the red box in the post above. Look down the p***age and check for blockage.I did this and had to shorten all my fittings as the went in too far.
  16. 51custom
    51custom
    I've had over a dozen Flatheads in my time, most without filters, 1 with MCF oil system in the early days, No oil pressure I had it replaced and found out that the drive gear on the back of the cam had cracked and would spin on the shaft, put on a new gear making sure the FLAT spot on the gear was in the right place...Worked fine, with my present Flathead I run with NO filter and change it often like the above quote..
    Jim
  17. 40FordGuy
    40FordGuy
    With the quality oils available these days,...<just add zinc> I stuck with the factory oil filter plumbing, only with a spin on unit; It's still a "partial" system, but eventually all the oil will p*** thru the filter. 3,000 mile changes....
    4TTRUK
  18. 40FordGuy
    40FordGuy
    ps; Just add zinc !
    4TTRUK
  19. doing some testing on this as we speek. I'll keep you all posted >>>>.
  20. Koz
    Koz
    I'm learning here! Can I just ditch the filter on my 8ba and plug the two holes that feed and return the oil to the filter? Or do I need to put a line between the feed at the rear and the return down by the pan? I don't mind changing the oil but i do think the p***ive filter is pretty useless and ugly to boot.
  21. Russco
    Russco
    from Central IL
    On the stock 8BA canister style yes, you can just plug the feed and return. The filter system they are talking about here is a full flow filter thats not stock.
  22. Koz
    Koz
    Excellent. I understand what this thread is covering. There are several systems that provide full or near full filtering. I was just wondering because of the discussion with the plugs closing of certain bores if I could do away with it altogether. Thanks for the info!
  23. AV88
    AV88
    Maybe it's not the filter system at all did the plugs in the crank get removed and the oil p***age inside the crank get cleaned out it could explain high oil pressure and why your main bearings are shot ? good luck
  24. 40FordGuy
    40FordGuy
    I use a spin on, with adapter, plumbed into the factory 8BA connections. Works great. Even though it is a "partial flow" system,..at some point, all of that oil will be run thru the filter.
    As mentioned,..the oils we have today were never even dreamed of, when our Flatmotors were brand new, as well as changing at 3,000 miles. When I was an apprentice, (mid 50's) it was still the custom to change oil at 1,000 miles, and filters every 5,000 miles. Hooray for the research and resulting products we have !!!!!
    Now,..put the zinc back it it !!!!!!!!!!!!!
    4TTRUK
  25. kendall66
    kendall66
    from iowa
    after my flathead was rebuilt i ran the break in period and changed the oil, ran for 200 miles and changed again, after that i have changed the oil every 1000 miles, all this and no filter.....no problems after 3 years and lots of miles.
  26. tig master
    tig master
    from up north
    8ba or 59a??
    Where are your lines going to on the filter adapter. You may have them reversed! That will lead to a problem..
    T
  27. nwbhotrod
    nwbhotrod
    from wash state
    NOOOOOOOOOOOOOOOOOO do not plug the holes
  28. Andy
    Andy
    If it is the old style that dumps back to the pan, you can just remove and plug. If it is a modern full flow, there is a plug in the p***age between the lines. You must remove the plug or no oil will flow to most of the engine.
  29. The testing I mentioned is complete. I had a customer that claimed his engine had 0 to 4 lbs of oil pressure and literaly no pressure when revved up. After 3 months of haggeling I tear the engine completly down for a complete check up and find no problems. I put the engine back together with new gaskets only. I then leave the add-on oilfilter off of the engine, plug the oil feed to the filter. I then start the engine on the run stand and bingo 17 lbs at idle, 47 lbs at 2500, and 88 lbs at 4500. I had voiced my opinion on the pressure that the add-on filter was robbing from the engine all along but the customer said back in the day they always used the add-on filters !! Then to top it all off Street Rodder Magazine print a 6 page article supporting my exact thoughts and proven theory on the same problems !!! >>>>.
  30. terryr
    terryr
    from earth
    Maybe the oil pump doesn't have the volume needed.
    Or if the filter is connected backwards it won't flow well, or not at all. They have check valves in them.
