Hot Rods Fully Fendered '31 A Coupe Rear Axle Width?
Discussion in 'The Hokey Ass Message Board' started by 31 Coupe, Sep 3, 2025.
  1. 31 Coupe
    31 Coupe
    Hello all,
    Looking for your recommendations of what the ideal rear axle WMS to WMS width would be for a fully fendered '31 A Coupe with stock fenders, 16" x 4-1/2" Ford '48 p***enger wheels, 700 or 750 tires please.
    Unfortunately my car is in storage and I can't get to it for measuring etc ..... this photo is the similar look I'd like to achieve.
    Thanks in advance.
  2. 19Eddy30
    19Eddy30
    from VA
    53 1/2 -54 28-32 Coupe , Roadster
    Drum to drum .
    S-10 2wd
    ( 28-32 truck not sure)
    If where a Sedan 28-32 , a S-10 4x4 , because wider @ fender wel
    Where rear sides windows lower there is humps for Tracks, Regulator & Gl***
  3. 31 Coupe
    31 Coupe
  4. 19Eddy30
    19Eddy30
    from VA
    @31 Coupe
    Just asking , did you not understand the measurements that I posted? does not matter if it's a S 10 rear or not those are the measurements,
    My self done A's & 32 s
    A&32 Coupes ,
    A & 32 Roadster's
    A &32 Sedan's
  5. 19Eddy30
    19Eddy30
    from VA
    This is Sedan inner fender ,
    This is why need the s-10 4x4 rear length
    I believe 56-1/2 over the
    53-1/2 54 , the narrower works I feel better Deeper front dish wheel
    & if want you can add
    1/4 to 1 inch spacer to move wheel tire flush to fender ,,, If to wide limited on
    Wheel then will be way to wide , hanging tires out like late 60's 70s IMG_3847.png
