Fun with motormounts!
Discussion in 'The Hokey Ass Message Board' started by Clark, Nov 7, 2005.
  1. Clark
    Clark
    I have fun making motormounts. Usually I come up with a different design for each car. Here's a couple. Lets see yours!
    Clark
    lothiandon1940, petersen43 and Jeff34 like this.
  2. bigken
    bigken
    Excellent designs, keep up the good work. Working on a couple soon, myself.
    BigKen
  3. InjectorTim
    InjectorTim
    Very cool, I dig the last one
  4. FiddyFour
    FiddyFour
    that 90deg split design is schweetness in schteel fab man :cool:
  5. ironworks
    ironworks
    here are some of mine
  6. trey
    trey
    man, my motor mounts are ****. and i thought they looked nice when i did them.
    i dont even compare.
    trey
  7. ProEnfo
    ProEnfo
    from Motown
    Here's mine..Littleman sez "holes are good"..
    CC
  8. joeycarpunk
    joeycarpunk
    from MN,USA
    Cool thread, nice creativity. Being tech week and all, how 'bout some tech post on building these or the thought process behind them?
  9. Levis Classic
    Levis Classic
    Where are you guys getting your biscuts for your motor mounts?
  10. ironworks
    ironworks
    I like the poly donuts for a 73-87 chevy truck cab. I usually buy the hole pack and use it for different stuff.
    Rodger
  11. Good ones Clark!
    Here are the set on my Model A with a 348
  12. Clark
    Clark
    Iron and Pro...nice mounts!!!!
    I used to get my biscuts from speedway but got a case of them at an auction. I'll be good for a couple of years now :D
    As far as tech...I do each one different. Mock the motor up and stare at it for a while. It will come to you. I do like using round tube when I use the biscuts.
    Clark
    lothiandon1940 likes this.
  13. Built2Ride
    Built2Ride
    Nice work. Cool how each is so unique. HAMB chock full o' talent.
  14. Canuck
    Canuck
    Trying for a OEM look. Hammerformed the frame mount with a little help from old bluetip,
  15. Nice work, guys!
  16. hillbillyhell
    hillbillyhell
    Here's what I came up with for my truck. One day, they'll get finished ground and nickel plated.
  17. 57JoeFoMoPar
    57JoeFoMoPar
    A real cheap option for motormount biscuits is to use vulcanized rubber stoppers, available in various sizes from the local hardware store. They're almost identical to '55-'57 Chevy rubber biscuits, and they cost less than $2. Just drill the appropriate sized hole through the middle.
    From an engineering standpoint, the biscuit styled mount is considereably safer. Many of the other mounts pictured, though extremely well fabricated and certainly strong enough to hold the engine, put the bolt through them in shear. For those style of mounts, I'd use no less then a grade 8 bolt.
  18. FiddyFour
    FiddyFour
    i seen a few guys use hockey pucks for body mounts,,, donno why they'd not work for an engine mount... any thoughts?
  19. 57JoeFoMoPar
    57JoeFoMoPar
    Would work and I've seen it done, but they're wide and harder than most rubber cushions I've seen. It would do very little to reduce vibration. They make great body mounts though
  20. Brandy
    Brandy
    from Texas
    I love these the most. They have style and function. FANTASTIC!
    **x
    Brandy
  21. zman
    zman
    from Garner, NC
    The ones I made for my roadster...
  22. dodgerodder
    dodgerodder
    Don't you guys know they now make BOLT-ON motor mounts, readily available hehe:D. I'm like you too Clark, I'll sit and stare for a while til it hits me. Some nice work guys.
    Heres mine for the olds 455 in my sedan
  23. burger
    burger
    Page 1218 of the McMaster-Carr catalog. I used P/N 9376K62 and I selected neoprene for its oil resistance.
  24. Dirty2
    Dirty2
    I finally think I am making progress on my Anglia and read this !!! Now I have to redo my motor mounts !!!:rolleyes:
  25. HRH
    HRH
    here are the set I made for Kevins lil bucket. I thought these came out kind of neat!!!!! Belly-pan/skid-plates are next but definately needed for a 1 1/2 scrub Tallest part of the car so far is right at 28 1/2 in.
  26. Clark
    Clark
    Lots of cool motor mounts!!
    Clark
  27. bcarlson
    bcarlson
    Cool mounts guys, I was looking for some ideas for some of my own. Anyone else have any that they'd like to share? The more the merrier!
    Ben
  28. bcarlson
    bcarlson
    bttt, I'd like to see any more ideas you guys have. Especially insulated mounts. Thanks,
    Ben
  29. Clark
    Clark
    Thought I'd bring this back up since I have done a few more mounts. The last set I even got creative on what I used for the bushing part. I used an A arm bushing from a 40's or 50's car. Unfortunately you can't see them in the pic.
    The other one uses a standard early Ford biscuit on a Y block.
    Clark
  30. InDaShop
    InDaShop
    from Houston
    Clark, kick ***. I'm exactly opposite, I always use a suspension bushing, but for my next set I got a set of the biscuits to try out and see what I can come up with.
    You're stuff is super cool! You always make it so hard to come up with something original when your always cutting edge.
