Technical functional yet traditional appearing air oil separator?
Discussion in 'The Hokey Ass Message Board' started by SDS, Jun 24, 2025.
  1. SDS
    SDS
    Anyone have pictures of a homemade or purchased air oil separator that looks traditional? I suspect I'm getting oil through my PCV line, so I want to install one to confirm my suspicions (and stop my oil intake).
  2. 2OLD2FAST
    2OLD2FAST
    from illinois
    Have baffles in your VC's ? If you want something to test with does it need to be traditional ?
    19Eddy30 likes this.
  3. 19Eddy30
    19Eddy30
    from VA
    Like 2old said..
  4. oldiron 440
    oldiron 440
    I agree with the valve cover question, I know of a situation where an engine builder was sued for oil consumption on the new engine and it turned out to be valve covers that the customer installed when installing the engine.
  5. 05snopro440
    05snopro440
    Wherever your PCV valve is located (valve covers, intake, etc.?), does it have a shield or baffle underneath?
  6. Use a cheap plastic fuel filter with a nylon filter element instead of paper. If it's just for testing then it should not matter what it looks like.
    2OLD2FAST likes this.
  7. A proper pcv system, with intake on one valve cover and PC valve in other cover, with proper baffles, actually works.
    Is it traditional?
    No.
    Cars from the 'traditional' period didn't effectively ventilate the crankcase, even with a road draft pipe. The result was often excessive gunk buildup in the valley and upper valve train area, shortening engine longevity.
  8. Kerrynzl
    Kerrynzl
    Stuff some of this down the line [pack it in but make sure you can still blow through it]
    SDS likes this.
  9. 19Eddy30
    19Eddy30
    from VA
    I cured a issue sucking oil up threw PVC one side , Little blow out other side for breather buy taken a piece of aluminum stock, by pressing into valve cover to
    3/16 towards , off top of head roof between rockers .
  10. SDS
    SDS
    Yes, but it's apparently not enough
  11. 2OLD2FAST
    2OLD2FAST
    from illinois
  12. miker98038
    miker98038
    Picture showing a little larger area would help.
    Is this what’s in the center of the photo?
  13. Maybe I'm wrong; but I don't think that valve cover rubber baffle will be adequate dropped into the valley like that. Think how big the can baffle was that Chevy used when they drew out of the valley. Maybe a deflector plate on the bottom of the intake in conjunction with that baffle might work.
  14. 2OLD2FAST
    2OLD2FAST
    from illinois
    I'm confused , that threaded boss in the manifold goes into the valley ?
  15. 05snopro440
    05snopro440
    What threaded boss? He's got a baffled grommet.
  16. miker98038
    miker98038
    If that “baffled” grommet is in an area with a lot of oil spray, it’s not working. Been there on the yblocks. Right above the distributor drive, oil flying at upper rpm’s, whole load of oil into a blown engine. 2 blown head gaskets, both on #7, and an oil filled manifold to prove it. It’s why I asked.
    Crazy Steve and jimmy six like this.
  17. Not to speak for the OP; but it looks like a hole was bored in the rear of the intake and a rubber valve cover grommet/baffle was inserted to be the source of crankcase air for the PCV system.
    Blues4U likes this.
  18. Could a washer, similar to bottom of pcv valve, with maybe a smaller hole, be put in grommet before inserting pcv, to alter the shape of the airflow?
  19. SDS
    SDS
    Yes
  20. I agree. This issue is one of the reasons why virtually all of the OEMs moved the PCV valve to the valve cover within a few years. By the late '60s this design was extinct.
  21. SDS
    SDS
    OK ...someone (thanks for the suggestion) suggested I try a transparent fuel filter to see how much oil is coming through the PCV. Man, it's prolific...
    That's the oil collected after a 15 minute cruise. I need to solve the problem vs collecting the oil as a bandaid.
    pprather likes this.
  22. miker98038
    miker98038
    That’s about what I’d expect to see from that baffle in that location. Y blocks use a valley pan, and I welded an aluminum baffle under the finned valley cover. Holes drilled opposite where the distributor is throwing oil. Not a big as the “can” an early sbc used, but more than enough to deflect flying oil.
    I’ve also done valve cover pcv’s, and tacked a baffle inside them. But those little duck bill affairs don’t seem to like being coated. They just suck it through.
  23. Oneball
    Oneball
    Where is the atmospheric inlet of the system? Maybe swap that to the vacuum side or just go the whole hog and use the valve covers
    SDS likes this.
  24. miker98038
    miker98038
    Oneball makes a good point. The 69 Camaro’s (and probably others) used an oil fill tube with a sealed cap and a threaded bung for the PCV. Your 69 Vette may have it. Reverses the flow. Still be nice to have a better baffle on the manifold end.
  25. 19Eddy30
    19Eddy30
    from VA
    @SDS
    How about Valley pan or
    Custom made ,
    Requires pulling intake , I know work to do,
    Make a round / box baffle with several shelf / layers
    Weld to intake underneath , or use
    Blind nail rivets to intake Underneath
    RICH B likes this.
  26. SDS
    SDS
    Custom making an in-manifold/valley air oil separator. Will 3D print in stainless...
    PXL_20250709_160508815.jpg PXL_20250709_160521298.jpg PXL_20250709_160539040.jpg
    And then fill with this before installing...
  27. 19Eddy30
    19Eddy30
    from VA
    @SDS
    That will work ,,
    I know you have access to 3d printer
    Why 3D ?
    Easily can be made with A piece of
    Tube , funneled down under intake ,
    Solder screen or Not ,
    Steel , SS ,aluminum or copper tube
    Your Steel /SS mesh & Gromit.
    How many Hours on that cad drawing,
    Writing the program, then 3Ding print?
    How does that work 3D printing
    S S , is it like the 3D ing Nylon plastic?
  28. SDS
    SDS
    The old ways of doing stuff take too long. I'd that time doing something else on the car.
    This was 30 minutes on the CAD model & 5 minutes prepping the print - use direct metal laser sintering printer. It's similar to printing nylon, but the powder bed is metal powder and the laser welds the layers.
    I made the wall thick thickness .045' to give the interior maximum volume. Will fit down into the hole in my intake manifold without removing the intake.
  29. 19Eddy30
    19Eddy30
    from VA
    @SDS
    If I had access and knew how to run these programs , modern equipment I would be making all kinds of crazy things and Vintage parts,
    I just have a 100 year old lathe
    & 60s Bridgeport
    deathrowdave likes this.
  30. SDS
    SDS
    "Just" ?
    That's more than most people have and I'm sure you can make too.
    You do have access to the printers...Protolabs.com
