Funnels Made Easy
Discussion in 'The Hokey Ass Message Board' started by Crystal Blue, Dec 4, 2013.
  1. blowby
    blowby
    from Nicasio Ca
    What I need is a better way to get 90w in a rear end other than laying under there doing the two arm squeeze on quart bottles, getting as much outside as in. I suppose a pump of some sort.
  2. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Since I'm a unretired teacher, this has special significance or me. I spent enough time in "the corner" to qualify for a special scholarship. I had more hours at school than the teacher.
  3. go-twichy
    go-twichy
    you mean "dawn"ed on us. . . .
  4. Crystal Blue
    Crystal Blue
    Heyyyyy dammit ! :) Start your own tech thread :eek:
    Friggin' kids, I tell ya:p
  5. Crystal Blue
    Crystal Blue
    Ingredients
    <!--concordance-begin-->
    • 2 cups milk
    • 1 egg, beaten
    • 1 teas**** vanilla
    • 2 cups all-purpose flour
    • 1 teas**** salt
    • 1 teas**** baking soda
    • 1 tables**** sugar
    • 1/2 stick (4 tables****s) melted ****er
    • Powdered sugar, for topping
    <!--concordance-end-->Directions
    Combine milk, egg, vanilla in a large bowl. In a separate bowl, combine flour, salt, baking soda, and sugar and gradually add to wet ingredients. Beat with a mixer until a smooth batter forms. Fold in melted ****er. Pour batter into a funnel or squeeze bottle while using your index finger to stop the flow of the batter. Bring the funnel over the hot oil and release your finger to start a stream of batter while moving the funnel in a circular motion to create spiral-like shapes. Fry for 2 to 3 minutes until golden brown and slightly puffed. Sprinkle with powdered sugar.
    As Eddie Murphy would say....You astd foe it ****wheat :)
    Damn.....I got to get a job. Retirement is rotting my brain :D
    <!--concordance-begin--><!--concordance-end-->
  6. cb1
    cb1
    from Wisconsin
    That is a great idea and will work great for topping of my snow plow motor. 1/4 inch pipe plug. Thanks, cb1
  7. A hose on the ******,
    A wire on the bottle
    An extra bottle with an air bleed hole.
    Hang the bottle anyplace you can.
    You can drink coffee or do something else more productive instead of squeezing but it isn't faster at getting it topped or filled its slower but automated.
  8. jkeesey
    jkeesey
    Get one of the old handivac caps that fits a mason jar. Make the hose that would be ****ing on normal use go all the way to the bottom. Pressurise the jar through the suction hose and it will push the oil up and into the rear. I use this setup for 600w gear oil in older cars.
  9. HOTRODPRIMER
    HOTRODPRIMER
    Hard to beat the old tried and true piece of paper in a pinch,,of course this type is not reusable. :D HRP
    Plus,you gotta admit it's traditional! HRP
  10. unkledaddy
    unkledaddy
    They give these away at a lot of gas stations;
  11. 56sedandelivery
    56sedandelivery
    They're giving away dunce caps at the service stations? Must be to attract teachers as customers. Butch/56sedandelivery.
  12. hotroddon
    hotroddon
    Gee, Ya mean like this?
  13. hotroddon
    hotroddon
    Ingredients:
    4 Laughing eyes
    4 Well-shaped legs
    4 Loving arms
    2 Firm milk containers
    2 Nuts
    1 soft, warm mixing bowl
    1 Firm banana
    Directions:
    1. Look into laughing eyes.
    2. Spread well-shaped legs with loving arms.
    3. Squeeze and m***age milk containers very gently.
    4. Gently add firm banana to mixing bowl, working in and out until well creamed. For best results. Continue to knead milk containers.
    5. As heat rises, plunge banana deep into mixing bowl and cover with nuts, leave to soak (preferably NOT overnight).
    6. The cake is done when banana is soft. If banana does not soften, repeat steps 3-5 or change mixing bowls.
    Notes:
    1. If you are in an unfamiliar kitchen, wash utensils carefully before and after use.
    2. Do not lick mixing bowl after use.
    3. If cake rises, leave town.
  14. blowby
    blowby
    from Nicasio Ca
    Those are hearing aides.
    I have one of those somewhere. As I recall laying under the car pumping 90w through that small tubing was worse. I like the air compressor hookup idea.
  15. saltflats
    saltflats
    from Missouri
    I use wood clamps to squeeze the bottle so my hands dont get tired.
  16. 53 COE
    53 COE
    from PNW
    HF has pumps cheap - and yes - they work fine with gear oil - it's not all that thick......
    http://www.harborfreight.com/sta-lube-gear-fluid-oil-pump-40714.html
    http://www.harborfreight.com/multi-use-transfer-pump-66418.html
    Just did the 8 3/4 rear on the Dart. Have 2 of the pumps, one dedicated for transfer case ****** fluid for the Duramax - and one dedicated to gear oil.
    And another extraction pump for that same 8 3/4 rear with no drain plug.
    http://www.amsoil.com/shop/by-produ...-pump/?zo=1220579&page=/storefront/g2576.aspx
  17. mashed
    mashed
    from 4077th
    "Do not lick mixing bowl after use."
    That's some funny ****.. umm, nasty batter right there.
    Hilarity.
  18. Bugguts
    Bugguts
    I like the "wood clamp" idea. Thanks salt flats.
  19. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Crystal Blue deserves better guy's. After all, his idea is from the heart. ;) :D
  20. falcongeorge
    falcongeorge
    from BC
    WTF??!! Thats the WIFES problem!!! GEEZ!:eek::rolleyes::p
  21. Not all of us have one of these catch all contraptions that you speak of:p
  22. beebing
    beebing
    from milwaukee
    If it's unfamiliar, I would stay out of it, otherwise wrap the utensil with plastic wrap and discard after use.
  23. falcongeorge
    falcongeorge
    from BC
    The main issue I find with them is they can be kinda noisy if you dont maintain them properly. :D
  24. 1955IHC
    1955IHC
    ^^^Most of friends have one of them. Seems as soon as they get one all their time is spent on it's maintenance and their cars end up getting sold. I prefer the single use version.:cool:D
    Sent via Illinois Bell Telephone Company's Car Radiotelephone
  25. blowby
    blowby
    from Nicasio Ca
    That's clever. Beats using your **** cheeks.
  26. BORRACHO13
    BORRACHO13
    from Menifee CA
    LMAO!! :D&#128517;
    Now that's good. I wanna get to bakin tonight
  27. Bump Stop
    Bump Stop
    from USA
  28. tommyd
    tommyd
    from South Indy
    Don't MAKE Ryan pull this car over and stop! Cause somebody's gonna be in big trouble mister!:p
  29. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    I'm stuck on 600W gear oil. Video please!
  30. choptop40
    choptop40
    funny thread.. in a pinch ,,cutup a bleach bottle , wrap and twist ..presto ..it and presto..instant funnel....just saying
