Hot Rods Fuse Block bad?
Discussion in 'The Hokey Ass Message Board' started by scoop, Aug 7, 2021.
  1. scoop
    scoop
    I got a Haywire harness for my Model A, got everything wired but no turn signals. Everything else works. Went over the instructions a dozen times all is wired right, so I took my tester and checked all connections, no juice coming out of the fuse block at the fuse with key on. Any suggestions or do you think this fuse block is bad? I've used these kits two other times with no problems.
  2. pprather
    pprather
  3. Make sure the fuse is good, if so then check to see if you have power at the fuse socket. Also check to see if you have continuity from the non-power side of the fuse socket to the switch. No power at the socket, probably a bad panel. No continuity, double-check your connections.
    5window, loudbang, Frankie47 and 2 others like this.
  4. squirrel
    Does the flasher can plug in to the fuse block? If so, have you figured out where the wires inside go to/from, and checked for voltage or continuity all along the way?
    Frankie47 and pprather like this.
  5. scoop
    scoop
    Fuse is good, checked at the socket no power, nothing to switch. Checked everything.
  6. squirrel
    can you get to the back side of the fuse block? or is it sealed up?
  7. scoop
    scoop
    Flasher plugs into block, one for hazard flashers separate one for turn signals. Hazards work, switched flashers no difference.
  8. squirrel
    did you measure for power at both sides of the fuse location, and both sides of the flasher can connection?
  9. scoop
    scoop
    I would have to remove four screws to do that, I don't know if I want to do that. I will call on Mon. to talk with them. After doing all this work I hope I don't have to do it again.
    Frankie47 likes this.
  10. Frankie47
    Frankie47
    from omaha ne.
    I think you will find it well worth your time and effort......by the way the last time I went through Blue Earth it was 1979......what a beautiful area it was.
